Just broken in
Barely 9,000 miles in 2ish years of ownership
Had 36,500 on it when I bought it
Is that a ScanGauge3? If so, how do you like it?60K.
It is! It's nice to have because the Honda Fit has no temp gauge.... No other auxiliary gauges either so I use the scangauge to monitor coolant temp and volts. Plus whatever else I feel like watching like spark advance and catalyst temp LOL.Is that a ScanGauge3? If so, how do you like it?
Can I ask how you accumulate so many miles?
Looks aren't its best feature, but utility, reliability and colour are.2008 Scion xB.
MPG readout is pretty accurate VS calculated at pump. Mostly country back roads, and some idling here and there. Not bad for a Camry 2.4L pushing a refrigerator through space & time.
At 227k the oil consumption is 1qt/4K miles. Using Valvoline Restore and Protect 5w30 to hopefully fix that. Although this consumption rate isn't bad at all for a 2AZ-FE, all things considered. May not even need a B12 Piston Soak.
Trusty workhorse, so a bit dirty.
377,777Mom's car today. I know, I need to take a duster with me next time I drive it...
Less than 1000 miles to where my R18 Civic died at 382k miles.
