Portable Generator
When I had my robin/subaru one cylinder unit, I'd exercise it once a month and do the whole stabil routine. Once I went to my 11kw kubota diesel, running it has become a bi-monthly routine, mostly just to keep the battery charged rather than worrying about the fuel or non-existant carb. Load testing became a yearly chore once I made the switch, mostly because it's not as easy with that kind of capacity-a space heater won't even change the tone of the engine. I've gotta break out two or three, and load on the garage lighting where it's planted to boot. The only way to really make mine break a sweat is to put on the central a/c in the middle of august.
I power my house by back feeding through my welder outlet after hitting the main and all 220 breakers. This works very well for me.
Cant wait to get this thing, I just dont fully trust the grid anymore. Our infrastructure is.......well you know. I wont go there.
I start up and run my little HF 2-stroker once every 3 or 4 months. I don't always put a load on it but occasionally I'll plug in a 200-watt drop light just to give it a load. About 30-min. of running then I shut off fuel supply to the carb and let it run dry.
No problems with it over the last 7-years and always starts right up.
I have a cheap 15 yr old Coleman 5 kw powered by a Tecumseh HM100. After losing power for 4 days, I got it running. I had to rebuild the carb and I added a shut off. I had thought I had blown the alternator up, but I just needed to reset the breakers. I used a dryer heating element to test it on 220. It sat for at least 6 yrs since it last ran. I should pull it out and try it.
Haha, yeah I would do that.
Was at the Honda dealer where I ordered the Generator from on Saturday. Now I`m told it could take until May to get it!
What did you wind-up buying?
Joel
I put a $200.00 deposit on the 6500kw back in November. They told me it would come in Feb or March at the latest. So I`m just going to stick it out and wait.
In michigan gasahol(e10) is mandated at the pump. I run my genny every 30 to 45 days. I start and run five minutes with 10% load to warm-up, and then run 50+%load til tank is dry (2hrs), top-off with fresh gas. oil used m1 truck&suv 5w30, changed every 50 hrs.
We don't have a genny, though I've been pestering my parents to get one for some time now, they won't do it until we own a house and can get a transfer switch installed. I've been thinking about picking up one of those 900watt "Sportsman" (chicago on HF) 2-stroke jobbies for emergencies.
We don't really have call to use them around here. National Grid does an excellent job keeping power up, and it's only when there are things like a tractor trailer crashing into a transformer, or a major ice storm, or severe thunderstorms, that we ever have any power outages. Occasionally we get short ones that last a minute to an hour or so, but anything longer than a minute is extremely uncommon.
Originally Posted By: Nick R
..I've been thinking about picking up one of those 900watt "Sportsman" (chicago on HF) 2-stroke jobbies for emergencies.
If anything, they're a good toy to have around, even if you need to give someone with a dead/dying battery a jump/boost.
Just don't pay more than a $100 for one. Wait 'till you get a HFT coupon or the likes.
Joel
Now notice HF has the Predator engine generators. Red
Wonder how these compare to the previous gens, the blue ones.
I'm fairly sure they are the exact same engines.
Not from the looks of them, nor from the way they're spec'd and marketed.
They're (probably) more inexpensively made, more emissions compliant and yet cost more to buy.
I bet the little blue 2-stroke generators aren't long for this world, soon to be replaced by cheap tiny OHV 4-strokes.
Joel
HFT had generous clearance on the blue 6.5 hp engines. $60 good. I hope for similar deals on their generators.
