I'm well over 300 hours on my Champion genset. Something has finally broken.
It's the little plastic lever that allows you to set the choke from the recoil side of the generator. You can still set the choke, you just have to go around to the other side to do it.
That's all. Everything else works.
I thought it had developed a class one leak, but then I noticed that I had accidentally pulled the crankcase pressure hose out while fiddling with that choke in the dark. Since cleaning off the dirt and oil, it's been clean and dry.
Individually, the parts look a lot like the other cheap Chinese generators that you get at PepBoys, Harbor Freight or wherever But it's different when you look at the details. It has a car size muffler on it that runs 3/4ths the length of the unit. The PepBoys genset muffler is a fraction of that size. The wiring is much more tidy. More attention was paid where it was welded. Like Champion is actually paying attention to quality control.
I was really conflicted. I didn't want to buy a Chinese genset but it almost quite literally 1/3rd the price of the "domestic" unit.
And it has performed flawlessly. Except for that cheesy little choke lever extension.
I run a little SeaFoam and regular 87 gas for...like 6 years now. Change the oil a little more often than recommended (100 hrs...I change around 60-70 hours) Check the valve clearance every once in awhile. Changed the plug once. (note to self: get new plug on way home)
I'm not so certain that I really want a "better" unit now. It hate to admit it, but I like this one
