Would you care to share your hypothesis regarding your claim?
Have you ever opened up a two cycle engine crankcase? I have.
I've owned a number of vintage two cycle Yamaha motorcycles and have had the engines apart. Even on severely flogged 40 year old engines, the crank case was spotless and devoid of "oil build up".
This is one of the engines I've rebuilt/modified, a 1974 Yamaha RD350:
[img:left]
[/img]
Originally Posted By: Mike72
Originally Posted By: Srt20
Originally Posted By: boraticus
Oil build up in the crankcase? Really?
Do you have any idea of what goes on in a two stroke engine crankcase? Believe me, there is NO oil build up going on in there. With the furious speed of reciprocating parts and violent flow of air/fuel mixture blasting through, nothing is settling or building up in there.
Nothing wrong with 40:1 ratio. It's my preference for everything other than liquid cooled engines which get a little less oil.
Two strokes (except for racing engines) need only a small amount of oil to function properly. Too much oil in the mix only increases the oil build up in the crankcase leading to more carbon/smoking and gains nothing. With today's oils, ratios around 50:1 are best with some synthetics going even higher.
X2. No build up happening. Two strokes are supposed to smoke. They burn oil. If you don't want a smoker buy a 4 stroke.
Respectfully disagree. Oil builds up in all two stroke engines especially at idle and lower rpms. The amount of this build up is directly related to the mix ratio. Higher ratios of 50:1 and up minimize the build up.
