Originally Posted By: tom in boise
Some of the original Cayman engines can have an issue with the failure of the Intermediate Shaft bearing, which then contaminates the engine oil supply and causes all sorts of other engine failure issues. Particularly on cars used for track days/racing. There are various engine mods people undertake to mitigate this potential, mostly centered around better oil control in the engine. This usually manifests itself as a deeper oil sump, perhaps with an improved internal baffle set up to ensure oil stays pooled around the pump pick up. Also and much more expensive is the addition of oil return pumps to ensure the heads are scavenged and the oil returned to the sump more effectively.
I will be adding a deeper sump arrangement to my Cayman this winter. I am contemplating installing the spin on filter arrangement at the same time. I use my Cayman for autocrossing and hill climbs, which are not as severe as tracking the car but are harder on the car then street driving. This last season I put on over 200 autocross runs on the car. That and hill climbs are all full throttle affairs, and the ambient temps in the summer can get around 100deg F.
FWIW - I use Mobil 1 0W-40 and the car consumed about 1 quart of oil this season total. I bought it last summer with 57k and it has 59k miles on it right now.
The IMS issue, if it applies to your car, should be upgraded to one of the aftermarket kits to deal with the issue. Bits and pieces of the bearing getting around the engine are not the real concern. It's the failure of the timing system, and the engine shortly after, due to a failed IMS bearing. The Porsche filter design is fine, imho.
I don't see how having a bigger sump will keep a non-lubricated part from failing. The original IMS bearing setup was a sealed bearing, and was not designed to be dependent on the oil volume. A bigger sump with better baffles could be a benefit in autocross or hill climbing. But it's already a nine quart capacity, and Porsche designed it to take corners pretty well I suspect. I'd spend the money of a larger sump on brake pads/rotors and tires.
