I've been using Delo 15w40 in my high mileage Legend (382k miles on the original engine) for over 100k miles.
On the Plus side, it has virtually eliminated the chronic tappet clicking that's characteristic of the old Honda V6. It took a while to do this, but IMO it's better than having to put ATF, Restore, etc. into the crankcase and is a bit more of a "permanent" fix than additives.
On the minus side, I used to get it in six gallon cases at Costco for around $38. Last time I looked, it's up to around $58/case.
There may be some negative affects to the converter because of some of the addtives in the Delo (heresay?), but I'm still passing bi-annual emission testing well below the acceptable limits.
