Good evening folks. The friend of mine with a 01’ Dakota said he wants to use some of the Providence HD 30 diesel engine oil in it. I said it’s not SP rated. He doesn’t seem to care. Anyone here ran a oil like this in older gas pickup?
I beg to differ from what this jug showsRural King's website says it is SN rated. If the temperature outside is above freezing, run it.
Dunno, he thought or thinks it will work fine. I said if below freezing good luck.What's he looking to achieve?
Yep. My jug must be older as Rural King site has jug looking same but it’s CK4/SN. My jug does not.Is it the 3.9 pushrod engine?
I'm not sure how their diesel oil can be both CF and CF-2....CF-2 is a low ash formulation for 2 cycle diesels like the old Detroit's. RK, Tractor Supply and Walmart all offer this kind of product. Shell Rotella T1 also touts being suitable for 2 cycles.Correct as I didn’t see the oil rated for gas engines. There was a spot on shelf and price tag etc. if he wants to run it I’ll gladly let him.
The CK4 HPL HDEO 5w30 is real smooth in my Dakota with same v6
Are you asking about the mono grade, or about the diesel only rating?So back on topic here; has anyone ever used this on an older gas truck? I know some friends of my late fathers with 60’s and 70’s or even 80’s era trucks use a mono grade.
Only if you poured it into itWill this stuff harm the catalytic converter
I don't think that old engine design will care.Yep. My jug must be older as Rural King site has jug looking same but it’s CK4/SN. My jug does not.
