I'm hesitant anytime someone makes a statement like that. Any vehicle made within the last 20 years is likely using a modern elastomer (FKM) for the various oil seals in a vehicle. Newer vehicles use Teflon. In either case with these materials, a conventional vs syntheticetic oil is not chemically different enough to just suddenly cause a compatibility issue on its own. I could see the seal getting hard and wearing out over time naturally, but for the most part oil is oil.
Exactly, the seal issues with syntheticetics were solved a long time ago.
1)
Originally Posted by bats
synthetic tends to be thinner and thinner leaks easier than thicker, and its possible
No, Syntheticetic differential gear oils and conventional gear oils of the same grade are exactly the same viscosity. Another internet misinformation tale. A badly worn seal is going to leak regardless of the viscosity of the oil or its base type.
https://www.bobistheoilguy.com/viscosity-charts/
MTL SPECIFIC fluids are slightly lower in viscosity for the same grade and use a different mix of base oils to improve cold weather shifting.
For a synchronized transaxle or transmission, one should use a GL-4 rated MTL SPECIFIC fluid because it has additive components that GL-5 differential lubes do not.
2)
...when i rebuild my rockcrusher i will still run non synthetic fluid as ive read too much that says people had syncro issues with synthetic in old muncies,
But your original question was about a transaxle in a trike.
Old Munices with decent synchro assemblies love the newer MTL fluids because they contain the proper friction modifiers which are great for the synchros.
3) Where are you going to find a fluid that does not have a syntheticetic component?
sounded easy but no, im in central fl, eustis and nothing i have found walk in carries a GL4 gear lube so i start my homework on it, while it would seem there is a ton of both facts and misinformation all jumbled together with lots of people just parroting what they heard, i do want to run fluid that wont kill my transaxle so i need the real deal on it.
4) And there are a number of technical articles on BITOG that explains differential and MTF fluids but it seems you have made up your mind regardless of the info you have received here.
Gear Tribology and Lubrication
Originally Posted by MolaKule
Manual Transmission (MT) Lubricants (Updated 5/20/2019)
Ever since dedicated MT fluids appeared on the scene (such as the GM Synchromesh series of fluid), drivers have seen better shifting due to better synchro engagement and improved shifter-fork movement, attributed to the specialized additive package used in these lubes. Before these fluids were introduced, engine oil's such as 5W30 or gear lubes such as 75W90's were specified, depending on design.
Note: This white paper is directed toward light truck and passenger vehicle manual transmissions. We will not be discussing transmission lubricants for Heavy Duty truck transmissions or those transmissions requiring MT-1 rated lubricants.
One of the first of these dedicated MT fluids were the GM Synchromesh series of fluids in the viscosity range of API 5W30 engine oils, or the SAE Gear Oil 80W85 range, or 10.5 cSt@100C. These fluids were originally targeted for the GM series of synchromesh transmissions. Purported to have been formulated by Texaco, these early MT dedicated GM fluids were partial syntheticetic fluids that contained a syntheticetic oil component of alkylated benzene for low temperature operation. The AW component was primarily a reduced level of EP additives with a low level treatment of ZDDP for anti-oxidant purposes. Later, the EP additive was dropped for increased levels of ZDDP as the primary AW additive. Today's MT fluids contain a multi-functional phosphorus chemistry as the primary AW additive with increased levels of syntheticetic fluids.
Then along came Pennzoil which introduced "Pennzoil Synchromesh" MTF with a 9.3 cSt@100C viscosity. This fluid fulfilled the specifications for both GM and Chrysler manual transmissions as their factory fill. Later, companies such as Amsoil and Redline introduced MTF's in various viscosities.
These fluids were successful because they introduced a specific friction modifier chemistry that insured smooth synchro engagement and disengagement.
Dedicated or Application Specific MTF's for Manual Transmission or Transaxle use an additive package containing Anti-Wear (AW) additives, rust and corrosion inhibitors, emulsifiers, and specialized Friction Modifiers, and are generally protection rated at the SAE GL-4 level.
Now GL-4 does not necessarily refer to MTF's, as there are some gear lubes in the
Market place that are GL-4 rated, but are not MTF's. GL-4 is an SAE wear protection rating.
There are a few MT fluids GL-5 rated for specific vehicles that have common MT and Differential sumps. One such manufacture, Subaru, has transmissions which shares a common sump and require a MTF which is GL-5 rated.
Manual Transmission fluids use a different Friction Modifier for synchro engagement,
a modifier that is NOT the same Friction Modifier chemistry as used in differential lubes,
engine oils, or hydraulic fluids.
Here, Friction Modifier or Friction Modification does NOT refer to friction reduction.
Here, Friction Modifier refers to a chemical compound that gives rise to a situation
such that the coefficient of friction (COF) varies Dynamically with respect to the
relative speed of parts that mesh and de-mesh during engagement and disengagement of rotating parts.
(For a similar discussion of ATF's and friction modification, please see:
https://bobistheoilguy.com/forums/u...TF_and_Friction_Modification#Post1111352 ).
When selecting a replacement fluid for a manual transmission or transaxle, one has to consider the viscosity of the fluid for which the manual transmission or Transaxle was designed. The spectrum of viscosities for light truck and passenger vehicle transmissions now range from 6.0 cSt@100C to 75W90 viscosities and therefore a dedicated MTF can be any viscosity from 6.0 cSt with an approximate SAE 70-75W80 grade ( a viscosity or grade similar to ATF's) to an equivalent SAE 75W90 grade viscosity of approx. 14.5 cSt@100C.
For example, if your transmission requires a 14.5cST@100C fluid, an SAE 75W90 fluid should be used. In some cases, a 75W85 syntheticetic fluid has been shown to provide better cold weather shifting, while still providing sufficient anti-wear protection and fluid film thickness. In many cases, one has to experiment with fluids of slightly different viscosities to determine which fluid works best in your local climate and specific transmission.
We should also mention that transmission wear can also require a change in viscosity as well. However, no OTC additive or change in viscosity will cure a transmission that has severe wear in its bearings, gear teeth, or synchronizer assemblies.
It is recommended that an examination of clutch engagement and a change in transmission fluid be done before rebuilding a transmission. For the latter, crunching and "notchyness" can be caused by the old fluid having been sheared (loss of viscosity) and the degradation of its additive chemistry.
Rather recently, many MT manufacturers have introduced fluid specifications for fluids with lower viscosities in the range of 6.0cSt@100C to 7.5cSt@100C, a viscosity in the same range as ATF fluids. These fluids were specified primarily to increase fuel mileage in order to raise fleet fuel mileage figures.
Some fluid manufactures' such as Royal Purple and the fluid supplier for GM, have developed MTF fluids in this viscosity range. These fluids are basically ATF fluids with a bump in the AW components.
One manufacturer, Tremec for example, currently specifies Dexron III/Mercon ATF fluids. It is the opinion of this author that the design of this transmission can only use ATF because of cold temperature operation problems. In earlier specifications, they specified higher viscosity MTF's, while in the latest specification, they specify ATF's, yet the internals are supposedly the same. My guess is they found that, with their original specs for the higher viscosity fluids, shifting was poor in cold weather, so they dropped the viscosity and at that point in time, the only available fluid with a low viscosity was ATF - which is no longer the case. Now there are new low viscosity fluids on the market with improved additive packages. In terms of the composite materials used in the ring-blocker assembly of these transmissions, the friction modifiers in ATF's do nothing for synchronizer operation. The shearing of the fluid at the interface is the primary means of dynamic friction modification.
Current MTF's in the range of 8 cSt to 10 cSt, designed for metal-alloy synchronizer assemblies, have been shown to work in these same transmissions without blocker-ring degradation or excessive wear.
One last comment: MTF specific lubes we're developed for manual transmissions and transaxles, and not for differentials or industrial gear boxes, and vice versa. A differential lubricant is not a good choice for MT's. A dedicated differential fluid of 75W90 with a GL5 rating usually has a higher viscosity than does an MTF in the same advertised grade, and will therefore cause shifting problems in cold weather. In addition, a differential lube does not contain the proper additive package needed for MTF's, since it contains an Extreme Pressure additive package meant for highly loaded hypoid gearing.
In summary:
1. GL-5 and MT1 rated gear lubes have a higher viscosity than MTF's of the same SAE Gear Oil viscosity range,
2. GL-5 and MT1 rated gear lubes have a different additive package than do MTF's; MTF's contain Anti-Wear additives, GL-5 and MT1 rated gear lubes contain Extreme Pressure (EP) chemistry.
3. GL-5 and MT1 rated gear lubes have a different additive package than do MTF's; MTF's contain specialized Friction Modification chemistry; GL-5 and MT1 rated gear lubes containing LS additives have special Friction Modification chemistry that is different than what is found in MTF's.
Here is an updated list of dedicated GL-4 and a few GL-5 MTL's.
Much confusion over the viscosities (thickness) of MTF fluids is the result of the SAE gear oil charts and its ranges seen at:
https://bobistheoilguy.com/viscosity-charts/
NOTE: This list is only a "suggested" list of MTFs. It is not an endorsement of any one fluid, nor is it implied that any one fluid will cure problems in MTs that have design problems or those that have excessive wear.
A. These MTL fluids are closest to a Kinematic Viscosity of 6.X cSt@100C (About the same viscosity as a Dexron VI) and SAE 70 or so:
1. Castrol Syntrans FE 75W,
2. BMW (Pentosin) MTF-LT-3,
3. Honda MTII or MTF 2.
4. Ford FML-XT-11-QDC
5. Volvo Manual Transmission Fluid (6.4 cSt) [Recommended for: type M65 5-speed with 6-cyl. engine, M66, MTX75 and MMT6 and of the type M56, M58 and M59 from and including model year 1996. Meets Ford specification WSSM2C200-D2]
6. Redline MT-LV SAE Viscosity Grade 70W/75W Vis 6.5cst@100°C
B. The next higher viscosity MTL would be the 7.0 to 7.6 cSt@100C versions (SAE 70W75) (About the same viscosity as the original DexronIII/Merc)
1. Royal Purple's Synchromax
2. Ravenol MTF-2
3. Honda MTF
4. VW part number G052512A2
5. GM Manual Transmission and Transfer Case Fluid
6. BMW (Pentosin MTF 2) MTF-LT-1, 2 ,3
7. Tutelo (Petronus, Italy, Product Code 1402)
8. Pentosin Pro Gear 70W75 (Australia)
9.0 Pentosin FFL-4
10. Redline Power Steering Fluid
11. RAVENOL STF
C. The next higher viscosity MTL group is in the 8.0 cSt to 8.9 cSt Range would be:
1. Castrol Syntrans V FE (8.0cSt)
2. Redline DCTF Dual Clutch Transmission Fluid (8.1 cSt)
3. BG Synchroshift II (8.2 cSt)
4. RAVENOL PSA
D. The next higher viscosity MTL group in the 9.0 to 9.5 cSt range is (SAE 75W80):
1. Mopar Type MS-9417 MTL 9.0 cSt
2. Valvoline MTF Part Number 811095 9.2 cSt
3. Pennzoil Synchromesh 9.3 cSt
4. RAVENOL PSA 9.5 cSt
5. RAVENOL SSG 9.5 cSt
E. The next group of MTL's are in the 9.6 to 10.X cSt range (SAE 75W80):
1. Redline MTL 75W80
2. Amsoil MTF (9.7 cSt)
3. GM Synchromesh's
4. Volvo MTF 645
5. Fuchs TITAN SINTOFLUID SAE 75W-80 syntheticetic MTF (Carries a GL-5 rating as well)
6. Lodexol (Morris Lubricants) MTF
7. Motylgear 75W-80
F. The next higher viscosity MTL would be a 12.0cSt@100C and SAE 75W85:
1. Redline MT-85
G. The next higher viscosity MTLs in the 14-15 cSt (SAE 75W90) range would be:
1. Amsoil MTG
2. Redline MT-90
3. Castrol Syntrans Multivehicle 75W-90
4. Castrol Syntrans Transaxle 75w-90
5. Ford XT-75W90-QGT (Carries a GL-5 rating as well)
6. Ford MOTORCRAFT® Full Syntheticetic Manual Transmission Fluid XT-M5-QS
7. ACDelco 10-4059 GL-4 75W-90 Manual Transmission Fluid
8. RAVENOL TSG SAE 75W-90
9. LiquiMoly 75W-90 GL4
