Plastic repair- whats your secret sauce?
My last repair lasted a couple years, highly doubtful you'll find a good one at the wreckers- just a crap design. Also thinking of straight up fiberglass resin. Will reinforce as well and torque bolts lightly, mounted on carpet. Drilled out the holes larger so any misalignment won't stress it more.
I repaired a cracked valve cover with this JB Weld product. 6000 miles on the repair and no leaks yet.
When I had the standard John Deere hood crack (starting from the handle) on my tractor, I used fiberglass drywall tape on the inside of the hood over the crack and slathered this stuff all over it. It has held solid for over eight years. That version of JD Weld, in particular, is great stuff.
Drywall tape has a little bit of adhesive in it that might interfere with a good bond. Any of the above glues (I like the plastex idea) would likely work better when combined with some fiberglass autobody mesh, or the cloth version of the same.
Epoxy would probably be too hard and prone to cracking, unless a JB weld type filler was used, if you have room.
