Originally Posted By: jblackburn
Originally Posted By: CrawfishTails
IF its slap you're hearing: ..... I'm curious as to if using a 0w-40 (any at Walmart, for example) would coat the piston skirts and cylinder walls a bit better and close up the clearance just enough to avoid slap.
Decent cold-start performance in a 0w-40, and they are premium oils in that grade. Sure they say use a 0w30 or 5w30, but I've never heard of a swithing to a 0w-40 as doing anything detrimental.
I would be curious as well - but that's far enough outside the 5w30 Dexos-1 specs that I'm not sure I want to try it while I still have a powertrain warranty.
You are already using a non-dexos1 oil, so forget warranty issues. Believe me, the higher-peforming Mobil 1 0w-40 meets even more stringent specs than dexos1. In fact, dexos1 actually uses some (not all) of the same Euro ACEA specs that 0w-40 does.
