Toy,
first, you are a canidate for running some full bottles of neutra through there to start with. I'd run at least 3 full bottles(1 each tank).
2oz per 19gal's way to low for it to be effective.
Pinging is normally caused by poor burning and poor gas. Most of the toyota engines are designed to run standard 87 octane fuel. In fuel, you have sulfur, which, when burned, turns into sufuric acid which becomes harden carbon attached in the cyl. This carbon, after being built up, will get hot while engine is running and act like a piece of coal, and stay real hot, so when the fuel goes into the cyl from the injectors, the hot coal carbon will ignite it before the piston gets back to the top of the cyl. This is where the cyl is "firing" and causing the engine to work hard getting back to the top, causes the engine to ping,(pre ignition knock), creates lack of perfomance as it is working against itself, and of course drives you insane. By increasing the octane of fuel, all you're doing is getting a fuel that burns slower than the 87, so that the coals in the cyl cannot ignite it as easily, and will cause the pinging to go away, but then because it isn't as efficent of a burn, it tends to leave more carbon in the cyls.
So, to help this, take and definatly increase the amount of 131 directly into the fuel. One thing that may happen as well is that when it starts to break things loose, it will cause the engine to run like crap, but just keep driving it for about 5 miles, and this will go away as it will keep cleaning the cyl.
Another little trick that one toyota mechanic told me he did after the neutra was to goto an aftermarket type of full flow air filter simular to the k and n, which increased his air. He stated that this made a good difference as well.
Another thing I did, was to take the 131 and do a spray into the plentum to help clear out the intake as well, but you do not want to just dump directly into it, but mist it in. This is one of the things the toyota does to help drivability problems such as that.
Hope that helps.
bob
[ September 16, 2003, 08:28 AM: Message edited by: BOBISTHEOILGUY ]
