It's a solved problem, but wanted to post it up here for others in case they have the issue. This summer, I noticed my P5 was pinging under load. I thought it was just heat and moved to higher octane fuel, but saw no improvement.
For the summer, I addressed the problem by simply backing out of the throttle when I would hear the pinging and it would go away.
Friday, I was checking under the hood for a weekend get-away trip and noticed the air intake hose was cracked. Makes sense. Un-metered air getting in and the engine was likely running too lean.
A look on-line shows my local O'Reilly parts store has the hose and for under $40 tax included and longer to drive there and back than to change the hose, the pinging is gone.
Just drove from STL to Cape Girardeau, MO and back this weekend and no pinging noticed.
Seems this is a common issue with Mazda and it must be as there is a Dorman problem solver part that stores seem to have in stock. I thought for sure this would be an order on line and duct-tape the hose until the part comes in, but it was available locally.
Sometimes it's the simple fixes for such issues, so don't forget to test such things.
