Originally Posted By: Gokhan
Is it a sewing-machine-like sound? It could also be valve clearances out of adjustment. If you have never adjusted them, it's probably time to do so. Your engine seems to require a valve-spring compressor and adjustment shims.
If it happens at high load and low RPM and sounds more like small detonations (kind of like popcorn being made), it's probably ignition timing and/or EGR. Check and adjust the igniting timing. If it doesn't correct it, check the entire EGR system and repair the faulty parts (heavy hard carbon deposits blocking the opening of the EGR valve, torn diaphragm in the EGR vacuum modulator, etc.). You can use a screwdriver as a pick and brake-cleaner fluid to remove the hard carbon deposits in opening of the EGR valve.
