Picked up some old razors
Originally Posted By: Shannow
As to the beard, a safety razor is way easier to make clean lines than a double/triple/quadruple/electric.
I agree with this 100%.
I've been using a 1950s Gillette red tip for several years now. Along with Feather DE blades (recently). Very good razor. I'd keep that one.
I came to the game late, around 1996. So, I have a Merkur 34C that I picked up for $20 in a mall knife store. I like it so much, there should never be a reason to change unless good DE blades become unavailable.
Originally Posted By: JustinH
I don't know, something about personal hygeine items and "used" doesn't sit well with me.
I use a disposable razor and throw it out after one use.
I'm sure if he dipped those in boiling water it would kill the cooties.
Most folks who use the old DE razors for daily use clean them well.
Here is my routine.
Scrubbing Bubbles gets rid of any soap scum build up and sterilizes it pretty well- spray let sit scrub, w/toothbrush repeat,follow up with dunk in bleach water and and a spraydown with Listerine type mouthwash, repeat and then rinse well with hot water.You can always buy some Barbicide or Marvicide sterilizing solution for use.
Most drug stores and beauty supply stores have blades.Wilkinson Sword is good,as are Derby's
and Personna's.Dorco's/Korean blades are hit or miss.Go on Amazon and you can pick up blades really cheap a year to two years worth of blades for less than 20 dollars.
My cleaning method consists of an hour or so in an ultrasonic cleaner. Then once they are dry I put them in a brass polisher to clean them up. After a few hours in the tumbler I hand polish them, and then give them a soak in Barbicide.
They are now probably cleaner/more sterile than they were when new.
All I have ever had to do to keep my Merkur clean is a wipe down with a dry microfiber rag. The razor is made of chrome plated brass. The top piece started losing just a bit of its plating a few years ago. An email to Merkur got me a new part for free. The razor still looks as it did the day I bought it.
I have used a variety of blades, but my favorite thus far is actually American made. I bought 100 Personna medical prep blades from Robbins Instruments for $30 (including shipping). More "expensive" than Derby, Israeli Personnas, etc., but still far cheaper than current blades and each one gives me a full week of excellent shaves. I could probably go longer than a week, but it is easy to remember to wipe down the razor and change the blade every Sunday. That has been my routine since the 90's.
Only thing else you could do is boil them or put them under sterilizing light. The blade is obviously new, can't see how hygiene or cleanliness even comes into the picture.
Impressive that you stock barbicide in your home.
Another advantage of safety razors is that you don't have to go hunting when it's time to recalk a shower recess...take the one out of the razor, and replace with a new Shark blade from the stash...of 300 odd left.
Good grief guys. They are used in SOAP.
What do you all do when you go to a hotel/motel, the sheets are washed in soap/detergent, go to a restaurant, dishes are washed in soap/detergent.
For heavens sake what do you all touch when shopping, what slim ball picked up that whatever before you?
Ever consider about the dust you breath while driving down the highway and the car in front goes over a road kill from 2 days ago.
Man up!
YES, I collect razors, YES Some of them I use. Been doing this for years.
Man up!
Some of the older razors have embedded soap scum, along with some corrosion. Given that there can be Staphylococcus, bacteria, and viruses embedded on a razor by scraping bits of your skin, I think I'll continue to both clean and sterilize.
I'll keep my personal hygiene standards, and you can keep yours.
What is a "slim ball"?
No problem with cleaning your razors, I think you took me a little wrong. I too clean all my razors when purchased, not a bad thing to do at all. We had one poster claiming he thru a razor away every time he shaved, to me that's a little over the top, but hey, its his money, not mine.
Most germs and viruses die within hours/days of drying out but its still a good idea to disinfect a used razor, I know I do.
What is a slime ball, can't help you there other than I see a
few most every time I go shopping.
There I fixed it with an extra (e), but I bet you knew what I ment anyway!
The razors included a Gillette "Red Tip", two Valet AutoStrop razors, and two Gem single edge "shovel head" razors.
Do you plan on shaving with any of them?
I shave every day with the "Red Tip"'s adjustable cousin.
They are built like tanks.
What exactly is this razor, and can they still be purchased? I need a new DE razor...
That's one of the old Gillette Adjustables, a Fat Boy I think. They also made a ligter model commonly called a Slim these days. Neither has been made for decades, & prices are usually out of sight on Ebay auctions. Check your local thrift stores, garage, yard, & estate sales. And don't turn up your nose at the non-adjustable old Gillettes either. They may not seem as cool as the adjustables, but even the plain old 3-piece Techs(the heavy ones, not the latter day aluminums), as well as the non-adjustable silo-door models like the Red Tip, Blue Tip, plain jane "silvertip", & the Aristocrat will give excellent shaves, equal to(maybe even better than) the adjustables. If you do get an adjustable, start at 2 or 3 unless you have skin like tough leather.
Good luck in your search.
BTW- my most often used razor these days is an old Gillette New(that's the model name), 3-piece, short-toothed comb, Canadian made, circa mid-late 1930s, with all the original gold plating worn off long before I got it. Still shaves great.
The Gillette Slim Adjustable is available on E-Bay for $45 w/buy it now. That's probably cheaper in todays money than what they sold for new.
I don't really need an adjustable (though it would cool), I have a Gillette Speed now that's coming apart and I need to replace it...
