Originally Posted By: Silk
Originally Posted By: Shannow
alkaline based degreaser hacked through it like no brake cleaner was able to touch.
I have a heated dip tank I use for cleaning some parts, and use those alkaline water based cleaners in it, only stuff I've seen to remove varnish completely. You can work really hard with some stinky solvents like brake and carb cleaner, or drop it in the tank and walk away.
Boiling water and automatic washing machine detergent (for coloureds, less bleach) has long been my primary weapon of choice for carburettor cleaning. Does tend to etch the (pot-metal?) alloy surfaces a bit though.
The varnish in neglected carbs is probably partly oil-derived, via crankcase ventilation.
Lately I've supplemented the washing powder with brake fluid, (not cleaner) which is also fully miscible with water.
Final clean with acetone, which also removes the water.
I use carb cleaner, but only for soaking small components, in a glass bottle.
Of course washing powder isn't directly relevant to in-engine cleaning, though I have heard of brake fluid being used as a soak for the combustion chamber.
