phone wiring...
And you should use a VDSL2 splitter to isolate the modem from the other "loads" in your house, which are your internal phone lines. The VDLS2 splitter has a separate connector for this.
The setup that i have is a dry loop.I only have Magic Jack,no voice line. I take it the splitter doesn't apply?
It only doesn't apply if the only line coming from your demarcation point goes directly to the DSL modem. If the other phone lines in the house are hooked up, live or not, they are still loads.
