Easily 10w30
Does ambient temperature matter? The engine still operates within a specified range.I know Honda recommends OW-20 for the 1.5 Turbo engines in the Honda CRVs. Being located in Phoenix, AZ, where outside temps hit 115F and pavement temps exceed 140F+. Would it be okay to run a 5W-30 synthetic oil like Pennzoil Platinum or Valvoline? The OW-20 seems to thin for this type of climate.
An engine's coolant temperature is well regulated, but the oil temperature is not, even if the engine has an oil cooler. Ambient temperature can affect oil temperature quite a lot.Does ambient temperature matter? The engine still operates within a specified range.
0w-20 could withstand temperatures of 400+An engine's coolant temperature is well regulated, but the oil temperature is not, even if the engine has an oil cooler. Ambient temperature can affect oil temperature quite a lot.
I'd go Royal Purple 10-40. Had great results with my Mazda rx-7I know Honda recommends OW-20 for the 1.5 Turbo engines in the Honda CRVs. Being located in Phoenix, AZ, where outside temps hit 115F and pavement temps exceed 140F+. Would it be okay to run a 5W-30 synthetic oil like Pennzoil Platinum or Valvoline? The OW-20 seems to thin for this type of climate.
Withstand it how? That would be some seriously low HT/HS. Not something I’d want in my engine.0w-20 could withstand temperatures of 400+
You neglected La Crème de la crèmeA few previous threads on this oft-asked question:
https://bobistheoilguy.com/forums/threads/hot-ambient-temps-and-engine-oil-question.180281/
https://bobistheoilguy.com/forums/threads/does-ambient-air-temperature-matter-or-not-for-oil.160299/
https://bobistheoilguy.com/forums/threads/oil-temperature-versus-ambient.247232/
https://bobistheoilguy.com/forums/threads/oil-viscosity-ambient-temperature-relationship.210129/
https://bobistheoilguy.com/forums/threads/grades-for-high-ambient-temperature-locations.151825/
https://bobistheoilguy.com/forums/threads/why-does-the-high-ambient-temperature-matter.231326/
https://bobistheoilguy.com/forums/threads/ambient-temperature-vs-engine-temperature.10616/
https://bobistheoilguy.com/forums/threads/oil-weight-and-ambient-temperatures.233545/
https://bobistheoilguy.com/forums/threads/thicker-oil-for-hotter-ambient-temp-why.273035/
https://bobistheoilguy.com/forums/threads/how-does-high-ambient-temperature-affect-oil.85142/
https://bobistheoilguy.com/forums/threads/does-ambient-air-temp-matter-that-much-for-weight.9656/
https://bobistheoilguy.com/forums/threads/at-operating-temp-why-does-outside-temp-matter.193826/
Royal Purple, great looking bottle, I have always wondered how long the Purple Color of the Oil stays Purple after you have driven it for a while.I'd go Royal Purple 10-40. Had great results with my Mazda rx-7
Heat exchangers do help, but they still don't regulate the oil temperature nearly as well as the coolant temperature is regulated. The oil/coolant heat exchanger on my Subaru keeps the oil temperature within 10°C of the coolant temperature in normal driving in normal weather, but it's still possible for it to get 30°C hotter than the coolant with hard driving in hot weather.Assuming the OP's vehicle uses an oil/coolant heat exchanger like most modern vehicles, the temperatures of oil and coolant are typically quite close together.
Is it 10 miles or 100 miles.
Yeah not all at the same time. Heat protection doesn’t mean simultaneous wear protection. Physics still matters.
I will just have to buy a quart of Royal Purple and get a Shot Glass and pour in the Oil and just leave it on my desk. I do have a Royal Purple Oil filter sitting on my Desk, nice Color.When I used RP about 15-20 years ago I recall that it didn’t even show up as purple on the dipstick when I checked it after idling the engine for 20-30 seconds after the oil change![]()
I have to disagree here. In any sort of normal climates, what you say is true. I have an old dodge truck thatI put an oil temp gauge in years ago. While living in Phoenix, the oil temp absolutely rose higher in the summer than the winter; the water temp was on the high side of boiling, and the oil got HOT.Ambient temp means virtually nothing. What matters is oil temp.
Really. Another strange issue that’s trying to be mysteriously connected to the octane rating of the fuel.Will run the 5w-30 Valvoline synthetic and a Wix filter.
I know it's another topic all together but are the head gaskets an issue with the 1.5 turbo engine in the CRV?
I read running HIGHER OCTANE fuel (91) will help with potential head gasket issues.
Really? my "old Dodge Truck" running on gas and lubed with oil is somehow radically different from a newer car with a turbo yet? New car oil doesn't get hot, stays magically cool under all conditions? I think not.In what way does your old Dodge truck compare to the OP's modern vehicle?
