- Joined
- Sep 26, 2025
- Messages
- 4
Not sure if this information is complied all in one place or not but im quite confused on all these additives and oils.
1. Starting with Philips 66 20W-50 aviation oil I have been told by Philips I can mix in up to 10% of Philips anti-rust oil into into my oil to gain more corrosion resistance. Are there any negatives to doing this? does anti-rust have any compounds that can be detected on a VOA? or is it something else being added.
2. I'm told that using Camguard can also help me with corrosion, should I also add Camguard to the mix above? are there differences between anti-rust oil and Camguard ? do i gain some other extra element in Camguard that is not in anti-rust oil?
3. Philips Victory contains an anti-scuff additive, since my engine doesn't require this do I gain anything from using it? in other words does adding an anti-scuff additive to an oil mix decrease wear rates or do anything else useful?
To me it seems overkill to make the following oil mix Philips victory 20w-50 add 10% anti-rust, add Camguard
