In Feb 2018 I installed a Penn Yan O-360 overhauled to new limits, in my C-172. Effectively, a new engine. I ran the normal recommended break-in procedures (high power, rich with shallow climbs to keep it cool). Oil consumption stabilized at about 1 qt per 15 hours, within the first 10 hours but I continued the break-in for the recommended 50 hours. After that I switched to Philips 20w50 AD.
Did the first UOA at the 5th oil change at 147 hours total (46 hours on oil). Everything normal except Aluminum (17/6), Chrome (33/8) and Copper (13/3) were elevated. Numbers are ppm in UOA versus averages. Blackstone says this looks high, they expect metals back to normal levels by now.
Oil filters and screen have been clean. Compressions are excellent (80/80 all around), borescope looked excellent. No obvious problems.
Next UOA at 42 hours later. Everything normal, but for the same 3 elements. Numbers below are: this UOA, prior UOA, averages for this engine:
Aluminum: 13, 17, 6
Chrome: 18, 33, 8
Copper: 10, 13, 3
I asked Blackstone and they said: Glad to hear that the engine is checking out on your end. The metals are heading in the right direction. Couple that with the good compressions and borescope results and I'd be really surprised if there's a problem developing. Best course of action is to probably just see how things look next time.
My prior engine failed (corroded cam lobes) without anything bad showing over 8 years of used oil analysis. So I had a bad engine with good UOA. Now it looks like I have the opposite: a good engine with bad used oil analysis. This is making UOA look pretty useless, with both a false negative, and now false positives.
I'm inclined to stop doing used oil analysis at all. Just inspect the filter and screen and maintain the engine on actual condition. Convince me otherwise; tell me why I shouldn't.
Aluminum: 13, 17, 6
Chrome: 18, 33, 8
Copper: 10, 13, 3
