Aeroshell W15W-50 VOA
Alaska
This is an Oil Analyzers/Horizon Aeroshell W15W-50 Ashless Dispersant Aviation Piston Engine Oil VOA with 5% by volume ASL Camguard Added.
It is marketed as “A semi-synthetic blend of base oils integrating ashless dispersant technology and advanced non-metallic anti-wear and anti-rust additive system, providing fast acting engine protection through oil drain intervals and in all seasons.”
I am told the base oil is 50/50 PAO/group II. The ASL Camguard additive seems to be almost universally recommended despite the prevailing philosophy to avoid oil additives in the automotive realm.
This is my source of that PAO claim, I don’t know if it is reliable; this formulation predates (or coincides with the early days of) the common use of group III I think? Thus, the additive. I don’t think its formulation has changed much since ~30? years ago when it first came out (regulatory/liability reasons?) but I can’t find a detailed history of all that.
Savvy Aviation Oil Recommendations
Aeroshell 15W-50 is 50% PAO. Exxon Elite 20W-50 is 25% PAO (which is a lot better). Phillips 20W-50 is 0% PAO (and 100% mineral oil), which we think is the best if you need multigrade oil (because you will be doing cold starts in sub-freezing temperatures without a pre-heat).
Obviously Savvy Aviation doesn’t like it but Aeroshell W15W-50 is the oil that is specifically called out to use in my engine and airplane manufacturers’ operating manuals.
Adding ASL or any aftermarket additive to a formulated oil skews the results, since we cannot know what ASL contributes to the elemental values. One should have two separate VOAs: one for the additive and one for the formulated lubricant.
Aeroshell 15W-50 does seem to contain significant PAO. As its use keeps internals markedly cleaner with orders of magnitude less varnish. And it is quite a bit better at preventing exhaust valve sticking than conventional aircraft engine oils.
Whether it is a better choice for an aircraft operator is another matter entirely. Clearly, flight schools get 3000 hours from abused engines, with regular shock cooling events, using the cheapest oil available. Does that mean the cheap oil is best, or that regular operation is best?
I recently switched from AS 15W-50 to Phillips 25W-60 (conventional oil) in an attempt at reducing oil consumption. My IO360 Lycoming is now using more oil than I'd like and compressions are in the low 70's. Bores still look great, and I suspect I'm experiencing the classic Cessna Cardinal ring tension loss due to poor cowl design. Maybe this oil will reduce the consumption, and also result in a stuck exhaust valve, like every other time we switched from 15W-50.
Interesting, how much time since new or overhaul on your Lyc IO-360? Mine is at 530/3 yrs snew and only uses about 1 qt per 20 hours, but I suspect some sticky exhaust valves are causing coughing/chugging on cold starts. Had to replace a fuel tank due to a leak on a metal fold which ended up taking a month - quoted a week. Had I known, I would’ve changed it to Phillips 20W-50 anti-rust oil before I took it into maintenance.
Engine has about 1000 hours since overhaul, 18 years ago.
Baffling was properly renewed at OH, and maintained well with leaks addressed. The '71 Cardinal RG is known to anneal piston rings due to poor overall cooling airflow. It came as no surprise when mine started using more oil than it should, right on schedule.
Flying yesterday, first flight after annual. Ran great! Roughly 10GPH, 143Kts TAS, 5500 feet. Clyde Cessna's direct reading oil pressure gauge is not really a calibrated indicator, but the 25W-60 oil clearly produces a tick higher needle position both cold and hot, than the Aeroshell 15W-50.
Very nice! They are imperfecct machines, and I wonder if we are deluding ourselves by thinking some operating trick or maintenance product can overcome that, but it still probably won't stop me from trying (after the seed gets planted about some new strategy by a mechanic, usually). To answer your earlier (tic) question, flying frequently is the best medicine for these engines, I just wish that I always had the weather, budget, and time to fly 2-3x per week!
Very nice! They are imperfect machines, and I wonder if we are deluding ourselves by thinking some operating trick or maintenance product can overcome that, but it still probably won't stop me from trying (after the seed gets planted about some new strategy by a mechanic, usually). To answer your earlier (tic) question, flying frequently is the best medicine for these engines, I just wish that I always had the weather, budget, and time to fly 2-3x per week!
As recently retired aviation professional, I've developed my opinions over time. Right or wrong, they exist. Agreed, frequent use is the secret to long engine life. Not just 2-3x per week, but that many per day, 7 days per week. The local parachute jump planes manage it this way. They purchase factory new engines, and go fly. According to the tech, they get well over 3000 hours and only have 1 or 2 cylinder changes towards the end. The plane goes up 5x/day, often to 14,000 feet, so it spends little time in cruise flight.
Contrast that with my plane, which is sporadically used, mostly for longer trips. I've never improved the cowl to the later style (a known benefit in cooling and speed) and despite 25 hour oil changes, have experienced a touch of cylinder bore corrosion and really I should install the NiCom coated cylinders to prevent problems.
But in the end, I tend to stay conventional and avoid too many alterations. Instead dealing with the known issues as they crop up.
Apparently the Aeroshell W15w-50 is a no VII oil. I included a few links below that expand on the properties of this oil from engineer Ed Kollin. I found them interesting and relevant to the subject of airplane oil formulations, specifically the content of Aeroshell 15w-50.
Aeroshell W15w-50 info
From Ed Kollin
Ed Kollin said:
First problem;
Polyalpha olefin (PAO), is the synthetic basestock used in AeroShell 15W-50 (at 50%) and Exxon Elite (at 26%) and the defunct Mobil AV1 (at 100%). It has excellent high and low temperature viscometric properties, high viscosity index (doesn't’t thin as much with increasing temp) and (low temp pour point) and good high temperature stability (when used with the proper antioxidant package). However, NONE OF THIS IS IMPORTANT FOR AIR-COOLED AIRCRAFT ENGINES! PAO has terrible solvency characteristics. It is so bad, that most additives will not dissolve in it. It needs to be combined with an ester (10-20%), alkylated naphthalene (5-25%) or mineral basestock (40-75% Aeroshell and Elite) just to get the additives to dissolve. This is fine for a heavily additized passenger car motor oil but NOT for a low additive treat rate oil used in a very high blow-by, leaded fuel aircraft engine. The ability to keep an engine clean by keeping combustion by-products in suspension is essential for an aircraft oil and the basestock works hand in hand with the dispersant to achieve this.
In my opinion PAO is the worst possible choice of basestock for piston aviation oils, and Exxon and Shell did not learn anything from Mobil’s AV1 spectacular failure. Mineral oils (non dispersant) by themselves, have difficulty solubizing the blow-by for long (witness the engine varnish with the use of non-dispersant oils) but it is nothing compared to the problem PAO has with it. The problem with Mobil AV1 was never the lead bromide (lead salt) particles, it has always been the partially combusted blow-by fuel in the crankcase that forms resinous varnish and captures the lead particles making a thicker deposit that is the problem. It was that way with Mobil AV1 and it remains so with the semi-synthetics.
The second problem;
There are two phosphate anti-scuff additives that meet the requirements of AD-80-04-03, and they can be used interchangeably with both of them having been sold as LW16702. One is butylated triphenyl phosphate (bTPP) and is currently used in the AeroShell 15W-50, W100 Plus and the Lycoming LW16702. The other is tricresyl phosphate (TCP) or methylated triphenyl phosphate, and it is used in the Exxon Elite. While they are used interchangeably to satisfy the AD, they act very differently in an engine.
bTPP, used by Shell and Lycoming, is a moderately good anti-wear owing to its ready decomposition and formation of sacrificial phosphate films on the surfaces of cams and lifters. The problem is that bTPP ALSO decomposes another way, in the presence of heat, water and metal all found in an engine crankcase. This decomposition is called hydrolysis and the breakdown products are oil soluble phosphoric acid derivatives that are corrosive to copper and elastomer seals. When Shell changed from TCP to bTPP in the 90’s people freaked that the copper levels in their oil analysis shot up. Shell responded by putting additional copper corrosion inhibitor in the oil. This protected the copper but left the offending acid products in the oil which left the seals vulnerable to attack. High silicon numbers in an oil analysis can be caused by the acid attack on silicone seals. Push-rod tube seals and valve cover gaskets are often silicone and prone to weeping problems. While no means a catastrophic situation, weeping seals, increased silicon in oil analysis reports, Retarded timing changes on Lycomings (from magneto pad degradation) have all been observed by the public, Shell and Lycoming.
Shell and Lycoming also say it is the addition of the Lycoming additive, bTTP, to oils already containing bTPP (AeroShell) that’s their story and their sticking to it.
bTTP is also a good friction modifier that can make marginal Continental adapters slip. It is NOT the PAO synthetic basestock that causes the slippage.
TCP, used in the Exxon oil, on the other hand is a much more stable molecule and as such, is completely ineffective as an anti-scuff/anti-wear. TCP is often used as an Extreme Pressure (EP) additive in grease but is never used as a primary anti-wear. Anti-wear conditions are much milder than EP conditions. For example, put TCP in an automotive engine as the only anti-wear, and the cam will quickly fail.
Ed
From Piper Forums user Domenick
Here Ed refers to Aeroshell W15w-50 as containing 5% viscosity modifier, so perhaps the formulation has changed over time or the Aeroshell marketing material depicted above is misleading.
Ed Kollin said:
I was directly involved in the disassembly of the Aeroshell 15W-50. I was in the room when we were informed that Elite would be an "advanced copy" (cheaper) of the Aeroshell 15W-50 and not a step out technology product. It only has 26% PAO synthetic base stock as compared to 50% in the Aeroshell. I left Exxon AFTER the Elite testing was complete and it was ready for release. My comments on rust test were meant to show that there is barely a significant difference between the Elite and the Aeroshell. They both contain 0.05% of a ferrous metal rust inhibitor. This is all they can use of that type without running into other problems. Exxons is just a little better than Shells. Camguard uses different technology.
Aeroshell 15W-50 / Exxon Elite
PAO synthetic base stock 50% / 26%
Dispersant (nitrogen) 3% / 3%
vicosity modifier (standard) 5% / 5% Viscosity modifier (dispersant)
Phosphate ester antiscuff 1% / 1.5%
Rust inhibitor 0.05% / 0.05%
Yellow metal inhibitor 0.05% / 0.05%
Anitfoam trace / trace
The other 40% of Aeroshell 15W50 and 65% of Exxon Elite are a blend of brightstock (heavy base stock) and solvent 600N (medium weight basestock). They are the mineral base stocks blended in proportion to meet the required viscometrics.
100% Synthetic oils are NOT used in Aviation air cooled engines, due to the inability to scavenge and suspend the Lead out of the 100LL fuel. Exxon found out the hard way. Yes, there was a Synthetic oil for aviation (Mobil AV-1) . There are aircraft that run on Auto fuel, but I know no one that uses an automotive synthetic oil with them.
There is also now 94 and 100 UL (unleaded) aviation fuel. There are issues with additives in these fuels, (used to bring up octane) namely Acetone, that are causing other internal and external issues. So until those are resolved, I don't see a true synthetic, piston engine oil for aviation anytime soon.
The AS 15W50 is a compromise, with an ok additive package. Having said that, it does NOT require camguard. Phillips 20w50 is great with camguard, but brings the price up to the cost of A/S 15W50 anyway.
Best route is single weight mineral with Camguard, such as A/S 100W. Pilots choose the multi-viscosity oils simply as single source for seasonal climate changes.
Thanks for contributing your views on the topic.
I’m not so sure it’s completely correct to say the Exxon AV-1 synthetic base oil was responsible for those problems. It seems that it may have been the total formulation, namely the selected additive package in combination with the base oil. I’ve been told by experienced users on this site there is no reason a group iii/iv/v “synthetic” base oil blend with a properly formulated additive package couldn’t be used in leaded fuel, air cooled engines (for example here). With 100LL on the way out, a properly formulated synthetic designed to accommodate lead will probably not be brought to market.
Ed Kollin has stated that he especially recommends Camguard with the A/S 15W-50. I get that he has a profit motive to say that, but I have no reason to doubt him. I agree that it isn’t “required”.
Beechtalk Forum “Aeroshell W15W-50 plus Camguard?“
I recommend Camguard in Shell W100 or Phillips 20W-50.
I strongly recommend Camguard in Aeroshell 15W-50 and W100Plus.
Ed
Maybe in some situations Aeroshell W100 is the best route. I’ve previously used it in an airplane that I didn’t fly much in winter time. For what I do now, I would rather have the better winter grade and higher viscosity index of the Aeroshell W15W-50 for my purposes and climate. I’m glad the Aeroshell 100 works for you though.
Correct. The poster’s conclusions aren’t exactly correct. It was an inadequately or improperly additized formulation which caused the issue.
I did say that in the future with 100 UL there is the possibility of synthetic oil use, not until the fuel issue is resolved. Nothing on the horizon.
I have met Ed in person, and he said Camguard was not require in A/S 15W50. Going on to say, it is overkill. ;)
However we dice it, the Av-1 could not scavenge the lead and lead to sludge build up. Wether it was additive or the synthetic base, the results were not good.
I actually use 15W50 all year round. I suggested CG and A/S 100W are a good combination. Won't work for people in colder climates or other factors.
