- Joined
- Aug 3, 2024
- Messages
- 253
2014 Nissan Frontier SV with almost 90K miles. I've never been a fan of the softer than usual brake pedal on this truck and I understand it's a known issue. Well it seems to have gotten worse, with enough pressure I can make it hit the floor. The fluid was flushed over a year earlier and no air ever entered the system. A new master cylinder didn't help, a "known good" used ABS module also didn't make any difference. No leaks and the pads and rotors are all good. I locked up the brakes on some gravel to activate the ABS and immediately bled over a quart through the system using speed bleeders, the pedal seems to stay off the floor now but there's still more travel than I like.
Here's the weird part. With the engine off and the booster bled down, the pedal is rock-hard and doesn't sink or feel spongy at all. As soon as I start the engine it goes soft again, I can't imagine it being the booster as that's not how they work.
Does anyone have any input? There's never been a brake or ABS light and I'm fresh out of ideas. Thanks in advance.
