I just thought I would share my experience yesterday as a result of this product. I was driving my wife's Rav4 and noticed the front brakes were making a grinding/groaning noise. I had done the front and rear pads and rotors using new Power Stop ceramics and Wagner Thermoquiet rotors. about 18,000 miles ago and had noted there was plenty of pad life left at 15,000 miles when I did a tire rotation.
The noise alerted me so I raised the front and pulled the wheels off. Pad life was still fine, so I dug deeper. I pulled the caliper off and noted that the pins were quite seized up. I had used Permatex ceramic brake parts lube (purple label jar). The product did not eat away the rubber dust boots, but after removing the slider pins (which took much force), I noticed that the rubber rings on the end of the slider pins that have them had swelled and was causing the pin to no longer move freely. Only the bottom pin on each front caliper has this rubber bushing/ring that looks like a little black rubber band.
I will also say that the solid metal pin on each size was also fairly seized up and most of the lubricant had dried up. This surprises me because this product has STELLAR reviews on Amazon and lots of others claim to use it on slider pins. In the future, I will only be using silicone paste on slider pins. This product might be OK for solid metal pins, but based on my experience I would not use it if your pins have rubber on them anywhere.
