So yesterday I finished replacing all rotors and pads on the Fusion. During the process, I found it disturbing that more than half of the slide pins were nearly seized! Now, this car is less than 5 years old and has 51,000 miles on it. It had some of the weirdest pad and rotor wear I've ever seen... maybe this is why. As with many vehicles, this car has different slide pins in the back than in the front. The rear has one solid metal pin, and one pin with a rubber sleeve near the bottom. The fronts have rubber sleeves on both pins. What is strange is that on most of the pins that had rubber sleeves, the rubber sleeves were what was seizing the pin, not corrosion or lack of lube. Upon close inspection, the rubber was trying to work its way up or down the pin during movement, binding everything up. On a 5 year old car? Insane! The rubber sleeves have either stretched, or swelled, but the grease on the pins is rubber-safe, so I don't see that being the issue.
So what I did, after some research, is remove all the rubber sleeves, period. My research told me that these sleeves are for (probably) sound/vibration deadening and possibly to relieve some minor slop in the movement, if any. Others seem to have had success doing this as well. I noticed upon reinstallation that any slop in the pins was about the same with as without those rubber sleeves. Everything was relubed with brake grease safe for rubber/plastic parts, and the new brakes are working great without a peep. This is what the pins look like. The one on the left is all metal per OE, and the one on the right is the pin without the sleeve, as I have it installed. Picture the pin on the right with a rubber sleeve in the indent towards the bottom; that's how they were originally.
One side of me wants to replace all of the sleeves with new ones, but who's to say this won't happen again?
