Originally Posted By: SteveSRT8
Originally Posted By: Oil Changer
Fair enough but I have yet to see of any of the maladies some members get on their soapbox about.
And you likely won't. But think of pouring 5% of the oil capacity of your engine in as GASOLINE. Might clean things up a bit, but in no way can it be viewed as an improvement, eh?
And that's only the part that still shows up as gasoline. Cold, incomplete combustion puts all sorts of unburned hydrocarbons, carbonic acid (CO2 + water vapor under pressure- PLENTY of that in the untreated exhaust that blows-by into the crankcase) traces of sulfuric acid from sulfur compounds in the fuel, etc. etc. All that stuff doesn't start coming back out of the crankcase until its over 100F in there.
OK- realistically ALL that is better than letting a battery freeze, or becoming stranded in the kind of cold that could freeze a battery. If THAT is the choice, sure! Idle the engine. If the battery is weak, don't risk it But how cold does a healthy, charged battery have to be to freeze? REALLY cold! About -75F for a fully charged battery. So assume even with a slight discharge you're not going to freeze the battery until -50 to -60F.
And every time you start the car and let it idle for a while, the battery charge is going down if you don't run the engine quite a while. The start removes a certain number of joules from the battery- more in cold weather than in hot weather- on top of that cold batteries charge more slowly than warm batteries too. Even in the warm, it takes more time than you think (5-10 minutes) to REALLY re-charge the energy removed by starting. There's a big initial charge, but charging is a chemical process. For it to be complete, the battery has to be held above the threshold voltage for enough time for all the cells and all the individual plates that make up a cell to come to chemical equilibrium with the electrolyte.
