I did manage to pop it out but found another at the very bottom , will be returning it. Too bad , the filter case seems soild, almost like a Purolator bossI either try to see if a pick tool can pop it out or return it. Chance would be high it would pop out under pressure IMHO.
Good eye!! Have to inspect every brand these days.
Too bad one would need the vision power of Hawkeye to be able to read the manufacturing date code lolOh no ... looks like a PG made filter with a defect. Guess it's their turn.
Good move on returning it since you can't pop-out the other hole at the bottom.
Isn’t oil flow velocity important?I did a pressure drop calculation for the cores on one of these Pentius filters, and it came out to 0.04 psi at 16 GPM. The force on the hole would be 0.002 pounds. I don't think it would come loose unless it were hanging on by a thread, but I still wouldn't chance it.
Yes, I assumed a total flow rate through the core of 16 GPM.Isn’t oil flow velocity important?
Looks great!!I just got a PLXL7317 in the mail. All of the holes in the centre core are open.
Initial impressions of this filter are good. It's very heavy for its size. The threads are well cut. The inlet holes are a bit small for my liking, but they're larger than the holes on the Purolator 14610/14615 or FRAM 9688/3593A filters. The gasket seems a bit thin (only 3.4 mm wide).
I was concerned about the small size of the bypass valves on Pentius filters, but the BPVs on the XL seem to be larger than they are on the Pentius PLB or Premium Guard filters, at least judging by the size of the metal valve support that's visible. This filter's too nice for a virgin C&P, so I'll check it out at the end of my next OCI.
The velocity through the holes is only around 0.1 m/s, hence the low pressure drop.What about the oil velocity hitting the center tube holes?
Do the dP on the inlet holes ... still low.The inlet holes are a bit small for my liking, but they're larger than the holes on the Purolator 14610/14615 or FRAM 9688/3593A filters.
I figure it would be around 4.8 psi at 63 L/min, which isn't that bad, especially since the rest of this filter should have low restriction.Do the dP on the inlet holes ... still low.
The FRAM 9688 and 3593A are around 7 psi, and the FRAM 7317 is only 1 psi. The OEM Subaru filter and the Pentius XL3593A are both around 2.7 psi.
Don't worry about base plate holes. They will all flow well enough to not make any difference to the oil supply to the engine unless you're driving around at redline all the time with 20W-50 oil. The thing to worry about it using a filter with choked down louvers.I wanted to ask everyone's opinion of the lower cost Pentius PLB7317 filters.
Do the smaller holes cause lower than average pressure?
Also, on the inlet I notice only 8 small holes (would this decrease the overall oil pressure to the engine).
