Penrite Mbike oil heavy foaming AVOID
This is one of the most confusing threads I've ever seen on here.
Quote:
the test was done with parameters that it was a diesel fuel
What does that mean?
different flashpoint tests. levels of soot and oxidation are expected to be higher ill be reposting the new analysis soon
There are different flash point tests for different oils? Not when I did them, it was agnostic to the material. I still don't understand what they mean when they said they said "the test was done with parameters that it was a diesel fuel".
OMG ur killing me.
IT WAS TESTED FOR PARAMETERS OF A DIESEL OIL
which means different flash points for the fuel, more soot is expected in a diesel oil sample.
Nobody is killing anyone. It still doesn't make sense, the test is the test and the results are the results. You can't run a test two different ways and get two different results. Somebody is making up something, somewhere. But I think this is as far as we are going to get.
Maybe when you post the new analysis... Is that ready yet?
OMG ur killing me.
