Found it !!
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4452669/1
We were talking about a different product from Nulon, but another thick oil
Nulon 25W-60 Street & Track, mineral oil, (API SG)
High Zinc (ZDDP) and High Moly (MoDTc) oil, TBN = 5.4, Zinc = 1900 ppm
KV40 = 276.9 cSt, KV100 = 23.92 cSt
Originally Posted by SonofJoe
To make a 25W60 like this, the oil's going to have to contain an appreciable amount of Group I Bright Stock. For those that don't know, this is stuff that you get from the Propane De-Asphalthing of Vacuum Residue (the heaviest and blackest stuff you get from an oil refinery). It will be very high in sulphur, nitrogen and aromatics. There are no Group II, II+ or III equivalents of Bright Stock.
Now don't get me wrong. I personally like Bright Stock. A couple of percent in a PCMO can work wonders, especially for things like diesel piston cleanliness. However, because of their high benzylic hydrogen content, they can be extremely oxidatively unstable. A very high ZDDP treat and a splash of Moly will only go so far in mitigating the problem and the TBN is worryingly low. Just don't try extended oil drains on an oil like this. In fact check the dip stick frequently because when this oil breaks, it will likely break very quickly. Leave an oil like this in too long unchecked and you could easily see its KV100 top 4000 cst at which point, your problem becomes one of 'how do I drain this stuff from my engine?'.
The 20W60 your mate (the one man pollution factory!) is currently using will contain quite a lot of VII. I'm guessing that it will have an aggregate base oil KV100 of around 10.5 cst. The Nulon 25W60 on the other hand will have a much higher base oil KV100. I'm going to assume this stuff contains no, or very little, Ashless Dispersant and no VII so the base oil KV100 is going to be around 20+. Bright Stock itself has a KV100 of around 33 cst which gives you an idea of just how viscous this stuff is. Couple that very high base oil viscosity with a shed load of ZDDP and some Moly and you have a very strong film strength lubricant.
I miss old Joe ...
