Pennzoil Ultra 5W20
Originally Posted By: beast3300
Holy smokes, thank you very much on the PU VOA sir. I can't even find PU here. :-(
Your welcome, I ordered it online on the 2nd of this month.
Originally Posted By: Ben99GT
Not bad, it will be interesting to see if Pennzoil Ultra 5w30 has the ~3100 ppm Ca count like Pennzoil Platinum 5w30. Looks like ZDDP was lowered a touch, but that could be Blackstone.
I recently did a Pennzoil Platinum 5w30 VOA and it came back just under 2800PPM Calcium
Amsoil is going to have to upgrade their little graphs on the internet so they can show their superiority to this influx of new oils. They are starting to look antique.
Originally Posted By: daman
Ya when did PP have 3100 ppm of Ca? not that i remember.
On my last UOA with Pennzoil Platinum 5w30 it showed 3257 ppm of calcium.
[censored]!!!
Impressive boron and TBN. Given the very high TBN, I suspect the boron is part of the detergent and/or dispersant additives as opposed to being something like borated esters.
Agree. Looks very good to me. Tbn is equivalent to SSO.
Motorcraft is the only other oil I know of using that much boron. In fact, Ultra is using more.
On my last used oil analysis with Pennzoil Platinum 5w30 it showed 3257 ppm of calcium.
[censored]!!!
My used oil analysis last fall of Pennzoil Platinum 5w20 showed 3075 ppm of Ca. 3100 ppm sounds like a good true average for PP.
From what I've seen, Pennzoil Platinum 5w30 typically has ~300 ppm Ca more than Pennzoil Platinum 5W-20. The add packs do not appear to be identical in the two grades.
Originally Posted By: PandaBear
10% vs 12.5% volatility isn't that big of a deal IMO, and for direct injection, usually the engine is designed with a large enough sump and OCI to compensate for it.
VW's problem is not oil, but its engine design (turbo and direct injection). Oil may only reduce this amount a bit, a typical extreme German engineering with minimal to no fail safe margin.
Just go ahead and spray sea foam or carb cleaner on a regular basis, that's the only solution.
10% is 20% less than 12.5%.
Lower oil volatility may be quite helpful in many hot-running engines. On my friend's VW 2.0T, after a two mile drive, steam will gush out of the oil filler cap when you open it.
Sounds like you are worried about splitting hairs
I'm very impressed with this oil on paper and by what spec's it meets.
Tbn of 13 for $6.97qt! Exceeds SN, HTO-06....what more could you want?
We're all splitting hairs when we are comparing synthetic oil to conventional oil anyway, so while we're at it, we might as well take it to the next level.
So, I have a Direct Injected Turbo car. Are you saying this is not a good oil for me to use b/c of it's volatility? I have a large stash of SynPower too, but I had planned on running PU next (currently GC is in). So is volatility the number I should be most concerned about in my application?
I don't think so. This oil should be one of the best at preventing deposits.
https://bobistheoilguy.com/forums/threads/motorcraft-5w20-quart-voa.124074/
Motorcraft apparently drastically increased their boron recently.
