Pennzoil Ultra 5W20
Originally Posted By: buster
Originally Posted By: shpankey
So, I have a Direct Injected Turbo car. Are you saying this is not a good oil for me to use b/c of it's volatility?
I don't think so. This oil should be one of the best at preventing deposits.
I agree
Other than the Boron level I see nothing special here.
A high TBN level does not a good oil make, it's just a high TBN level.
Blackstone unfortunately doesn't provide a 40C vis measure and therefore no VI but based on the PDS info 158 is very mediocre.
Now, for those of you that are openminded and want to see what an exceptional 20wt VOA looks like check out the VOA of Toyota's 0W-20.
It sounds like you are the one who is not open minded.
I agree
Quote:
If I agreed with you, we'd both be wrong.
Ok, now I'm confused. lol
Originally Posted By: Bill in Utah
So is that a turbo motor?
Yup...and Direct Injected. DI is the main issue. Low volatility oils may reduce some of the deposits that you see on those intake valves.
So, I have a Direct Injected Turbo car. Are you saying this is not a good oil for me to use b/c of it's volatility? I have a large stash of SynPower too, but I had planned on running Pennzoil Ultra next (currently GC is in). So is volatility the number I should be most concerned about in my application?
In a turbo engine which typically can see much higher regional temps than NA engine, I would be more concerned with HT/HS value. This Pennzoil Ultra 5w-20 oil isn't so great in that regard. GC is much better in comparison.
GC is a thick 30-weight (near 40-weight)... no kidding it's HT/HS would be higher than a 5w20. :P
Little bit of an apples to oranges comparison. Have to compare same weight oils and even then of coruse there will be different from different oil companies.
Originally Posted By: Taylor
What's the HT/HS on this?
2.7
Link to Shell's spec sheet is on page two.
For comparisons sake: redline
TYPICAL PROPERTIES
API Service Class SM/SL/SG/CF
Viscosity Grade SAE 5W20
Vis @ 100°C, cSt 9.1
Vis @ 40°C, cSt 55
Viscosity Index 145
CCS Viscosity, Poise, @*C 50@-30
Pour Point, °C -45
Pour Point, °F -49
Flash Point, °C 251
Flash Point, °F 484
NOACK Evaporation Loss,1hr @ 482°F (250°C), % 8
HTHS Vis, cP @150°C, ASTM D4741 3.3
Here is the VOA typed out. I read an opinion in another thread and it gave me an idea to do this.
Aluminum 0
Chromium 0
Iron 0
Copper 0
Lead 0
Tin 0
Molybdenum 44
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 373
Silicon 3
Sodium 0
Calcium 2752
Magnesium 10
Phosphorus 629
Zinc 700
Barium 0
SUS Viscosity @210F 52.7
cSt Viscosity @ 100C 8.1
Flashpoint 425
TBN 13.0
  • Like
Reactions: pbm
I wish that 40*C # was lower.
Originally Posted By: Patman
I believe Boron is mostly for cleaning but that it also has some antiwear properties too.
Link
Originally Posted By: river_rat
Antiwear additive?
According to the Pennzoil Ultra FAQ
13. A VOA performed on this board showed a significant amount of boron in the formulation of Pennzoil Ultra™.
The function of the boron in Pennzoil Ultra™ formulations is one of protection for non-ferrous metals and sealing materials.
Quote:
aaha, so its the boron that gives this oil the extra 35% in cleaning power over PP gotcha!
Not really. Most likely a Boron ester or phosphorylated Boron for AW and FM.
