So, as I've feared it appears coolant is finally getting into the engine. The previous results can be seen in the image file below. I used Lubro-Moly MoS2 with this oil, hence the higher moly.
Does this mean a headgasket is likely the cause? Is there any other point of entry in the oil from the cooling system? Thank you.
Oil filter used: Royal Purple 10-2808
Air filter used: aFe Pro Dry S(for last half of the OCI, away from K&N...only real positive trend, sigh lol)
Code:
OIL PENNZOIL ULTRA 5w-30
MILES IN USE 7,500
MILES ON UNIT 265,000
SAMPLE TAKEN 06/06/12
ALUMINUM 3
CHROMIUM 1
IRON 23
COPPER 6
LEAD 8
TIN 0
MOLYBDENUM 281
NICKEL 1
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 51
BORON 146
SILICON 14
SODIUM 173
CALCIUM 3268
MAGNESIUM 26
PHOSPHORUS 798
ZINC 893
BARIUM 0
SUS VIS 210ºF 59.3
cSt @ 100ºC 10.01
FLASHPOINT ºF 420
FUEL%
ANTIFREEZE% 0.35
WATER% 0.0
INSOLUBLES% 0.5
http://img84.imageshack.us/img84/1884/4thvxreport.png
Code:
MILES IN USE 7,500
ALUMINUM 3
CHROMIUM 1
IRON 23
COPPER 6
LEAD 8
TIN 0
MOLYBDENUM 281
NICKEL 1
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 51
BORON 146
SILICON 14
SODIUM 173
CALCIUM 3268
MAGNESIUM 26
PHOSPHORUS 798
ZINC 893
BARIUM 0
SUS VIS 210ºF 59.3
cSt @ 100ºC 10.01
FLASHPOINT ºF 420
FUEL%
ANTIFREEZE% 0.35
WATER% 0.0
INSOLUBLES% 0.5
