Red Line 5W-30, 2014 Focus ST, 5000 mi
Milford DE
Switched to Red Line on latest fill after Pennzoil Ultra was discontinued. Very pleased with the results. Going to push the next OCI out to 6K.
Code:
OIL RL5w30 PU5w30 PU5w30 PU5w30
MILES ON OIL 5,000 5,111 5,127 3,200
MILES ON CAR 21,142 16,142 11,031 5,904
SAMPLE TAKEN 6/20/14 5/2/14 3/15/14 1/22/14
ALUMINUM 2 7 4 3
CHROMIUM 0 1 0 0
IRON 12 12 12 10
COPPER 12 17 41 57
LEAD 1 0 0 0
TIN 0 4 0 1
MOLYBDENUM 511 52 52 50
NICKEL 0 0 0 0
MANGANESE 0 0 0 1
SILVER 0 0 0 0
TITANIUM 0 2 2 2
POTASSIUM 7 19 5 4
BORON 80 80 90 102
SILICON 16 13 15 17
SODIUM 12 4 5 3
CALCIUM 2533 2300 2259 2308
MAGNESIUM 9 23 23 35
PHOSPHORUS 1162 711 704 738
ZINC 1251 832 816 760
BARIUM 0 0 0 0
SUS VIS @ 210ºF 59.0 53.9 54.6 54.0
cSt VIS @ 100ºC 9.92 8.46 8.64 8.49
FLASHPOINT ºF 415 410 400 390
FUEL %
ANTIFREEZE % 0.0 ? 0.0 0.0
WATER % 0.0 0.0 0.0 0.0
INSOLUBLES % 0.2 0.3 0.4 0.4
TBN 4.6 4.1 4.4 4.4
It didn't shear down like the others.
Your wear metals are trending down as they should with a newer car.
Nice!
How much more is the Redline vs another 5w30 synthetic? If you're paying 50% more, I don't see that you're getting 50% more performance with the Redline.
cst 9.92 after 5000K?
RL is HEAVY 5W30 oil. It is Euro spec 5W30, and 9.92cst after 5K is nothing spectacular!
You might try Castrol 0W30 and see how it works!
Wouldn't a 9.92cST be on the low end of a 30 grade oil? Looks to me that the RedLine 5w30 stayed in grade (9.30-12.49cST) and the 5w30 PU sheared out of grade (to the high side of a 20)
Wouldn't a 9.92cST be on the low end of a 30 grade oil? Looks to me that the RedLine 5w30 stayed in grade (9.30-12.49cST) and the 5w30 Pennzoil Ultra sheared out of grade (to the high side of a 20)
Yes, but Pennzoil Ultra 5W30 starts lower then RL. RL starts at 11.9.
For example, when I did UOA on Mobil 1 0W40, it sheared from 13.5 to 13.3!
The Mobil 1 ESP 5W30 that I use now starts at 12.1, and after 3.3K sheared to 11.07. I will do UOA again at 5K to see, but I think 9.9 is too much for oil that is heavy 5W30 unlike Pennzoil Ultra 5W30.
I do not think there is any problem, but actually I am surprised it sheared that much. Also, this result does not justify price of almost $12 per quart.
I would try Castrol 0W30 which is proven as shear stable and starts at 12.2cst.
Red Line is HEAVY 5W30 oil. It is Euro spec 5W30, and 9.92cst after 5K is nothing spectacular!
I would seriously doubt GC would stand up any better. I've used both GC and Red Line 5w30 in my WRX and Red Line stood up much better. I'm guessing a bit of fuel dilution is the reason for the lower viscosity, not shearing.
I was about to say that it could be engine type.
Now fuel dilution, IDK, I have VW 2.0T which has known dilution issues, but never had drop in viscosity like this, and I do push car very hard.
Also, as far as I know Red Line changed their formulation a bit.
Originally Posted By: SXE10
Ecoboost engines are direct injection so fuel dilution may well be at play here
Yeah, I heard that it is more of a problem then on VW, but his TBN is OK and fuel is less then 0.5%.
Yes, but Pennzoil Ultra 5W30 starts lower then Red Line. Red Line starts at 11.9.
That's all largely immaterial.
Red Line 5w30 has a HTHSV of 3.7cP with a modest 166 VI which puts it on par with a 40 grade oil like Mobil 1 0W-40 at operating temp's.
In this application the OP really should be using Red Line 5W-20 (Red Line advises dropping a grade when switching to their oils) which is on par in terms of operational viscosity with a typical 5w30 like Pennzoil Ultra.
BTW, isn't the 2014 Escort spec'd for 5W-20?
You like to sound like an expert but then you spit out something like 2014 "escort."
Even then, assuming you mean Focus, no, it is not.
Yeah, I screwed up, forgot this was an Ecoboost.
And as far as what I'd like to sound like it would be Bocelli, Pavarotti or Damingo but unfortunately that's not the case.
