Originally Posted By: pbm
What would Dr. Haas say about this?
He'd say the Pennzoil Platinum 5w30 was too thick.
Then he would say he used a 0W-20 that actually was more like a 40-weight, but says 0W-20 on the bottle, even though HTHS would beg to differ, and put it squarely in thic 30, even close to a 40-weight category.
Then he would say that it was absolutely a 0W-20 when questioned.
Just remember, when reading Dr. Haas's articles: he uses what it says on the bottle.. the HTHS of the oils he uses are a LOT more favorable to the engines they are in, and are more like mod-30 *mid weights and such. He just doesn't call them what they actually are, and it leaves a lot of Dr Haas technical data readers going out and buying things like Pennzoil Platinum 5W-20 and such.... which may or may not do things like it did in their BMW, which clearly say HTHS 3.5 or higher like Porsche.
Basically, Dr. Haas's 0W-20s have HTHS 3.5 or higher. How that is possible, I don't know.. but, hey, he says so. Then, when examined closely, the oil is actually thicker in HTHS than he will ever admit.
And yes, I imaging he will be the first to put the new 0W-16 in a Rolls Royce. It will probably be Motul or Fuchs or something, and that 0S-16 will probably a light 30 lol, which will make the engine run smoother than an BMW RR FF... ...maybe he will drain all the oil out so that the heard metal-on-metal for 11 seconds, like he did with a Ferrari 599.. If you ever read what he says...
