Hello there Bitog. Long time lurker, first time posting.
Here are the Technical Data Sheets for Pennzoil Platinum PurePlus, API SN/ILSAC GF-5, as published by Shell Oil Products. All files are in PDF format.
Pennzoil Platinum PurePlus SAE 0W-20
Pennzoil Platinum PurePlus SAE 5W-20
Pennzoil Platinum PurePlus SAE 5w30
Pennzoil Platinum PurePlus SAE 10w30
SAE Viscosity Grade: 0w-20
Density: 0.838 g/cm3
Flash Point: 224°C
Pour Point: -48°C
Viscosity @40°C: 45.3 cSt
Viscosity @100°C: 8.3 cSt
Viscosity Index: 168
CCS Viscosity @-30°C: 5,650 cP (-35)
MRV Viscosity @-35°C: 14,100 cP (-40)
Noack Volatility: 10.8%
Specifications: API SN, ILSAC GF-5, Chrysler MS-6395
SAE Viscosity Grade: 5w-20
Density: 0.839 g/cm3
Flash Point: 224°C
Pour Point: -51°C
Viscosity @40°C: 44.9 cSt
Viscosity @100°C: 8.2 cSt
Viscosity Index: 158
CCS Viscosity @-30°C: 4,000 cP (-30)
MRV Viscosity @-35°C: 9,000 cP (-35)
Noack Volatility: 8.6%
Specifications: API SN, ILSAC GF-5, Chrysler MS-6395, Ford WSS-M2C945-A, GM 6094M, dexos1
SAE Viscosity Grade: 5w30
Density: 0.84 g/cm3
Flash Point: 224°C
Pour Point: -48°C
Viscosity @40°C: 56.9 cSt
Viscosity @100°C: 10.3 cSt
Viscosity Index: 170
MRV Viscosity @-35°C: 10,500 cP (-35)
Noack Volatility: 10.1%
Specifications: API SN, ILSAC GF-5, ACEA A1/B1, A5/B5, Chrysler MS-6395, Ford WSS-M2C946-A, GM 6094M, GM 4718M, Honda/Acura HTO-06, dexos1
SAE Viscosity Grade: 10w30
Density: 0.843 g/cm3
Flash Point: 224°C
Pour Point: -48°C
Viscosity @40°C: 63.3 cSt
Viscosity Index: 150
CCS Viscosity @-30°C: 4,150 cP (-25)
MRV Viscosity @-35°C: 8,500 cP (-30)
Noack Volatility: 4.7%
Specifications: API SN, ILSAC GF-5, Chrysler MS-6395, GM 6094M, GM 4718M
Flash Point: 224°C
Pour Point: -48°C
Flash Point: 224°C
Pour Point: -51°C
Density: 0.84 g/cm3
Flash Point: 224°C
Pour Point: -48°C
Flash Point: 224°C
Pour Point: -48°C
