Hey Ordnance,
Good to see you over here. I'll give my interpretation of your results as someone with 23k miles of UOA history with blackstone on a '06 SI. First though, here's my latest:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1306650&fpart=1
Since then, I've got another ~8k on a fill of AMSOIL SSO 0w30. I'm going to run it to 16k and sample. I'll make sure you see it.
Your UOA looks great, first off, and at your low mileage I'd be curious about the effects of background noise. Your engine is REALLY still breaking in....
Your wear metals are a little high, but your oil was in for 60% of the car's life.
My recommendation, based upon my own experiences, is to switch to SSO 0w30 after your next fill and run for 10k....even with your modifications. You do shorter trips than me, but your engine is probably running a little less rich than mine (definitely not lean though).
Now, saying that, I still think you are so easy in your car's life that it's hard to make much determination. These cars have such great little engines that you can pretty much do nothing run as long as you change the oil on time. You are most likely shifting at 8300-8400 tops, as that will give you the best powerband use, so I doubt you are getting Tin wear due to beating on it (unless you spent some time brushing into the new 8600 rpm fuel cutoff, in which case maybe).
I'm betting your next sample of PP will show across the board decreases (unless your new filter doesn't do it's job). If you are interesting in running 10k oil changes with a wonderful oil, switch to SSO and I'd put money on wear going below PP levels.
Nonetheless, this is great. My back-up plan has always been to switch to PP 5w30 for 10k intervals, since I've got so many gallons in my basement for use in the Legacy GT. Good to see what it can do in an SI.
Joe
