Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles
Here’s an update on the Sienna. Switched oil to 5W30 Walmart Supertech synthetic. The oil was in for 8 months and most commutes were daily, less than one mile total distance. It saw a few longer distance trips of 600 miles. A fair amount of idle time.
This particular engine is seeing very short trips most of the time; fuel and wear rates will be elevated. Plus this engine series wears a bit more than others. The Cu elevation is what is perplexing. I personally don't think you're out of the woods yet.
But, because you basically bought it as a DD beater (low investment = low expectations) I'd just drive the wheels off it. Do the UOAs if you simply enjoy them. If you're into experiments, consider trying a dino oil 5w-30 and see what changes, if any, may happen. Can't hurt at this point!
The UOA’s is a hobby with this vehicle. I’m interested to see how long I can drive it. I’m not too overly concerned about the CU until I see a trend. The motor was down about 1 quart at change/sample time. I didn’t replenish it. The oil sample came after a 600 mile trip. I’m sure the fuel % was higher before the trip which added to the wear.
Lots of idle time, a lot of short trips, fuel dilution, towing, and winter in a 230k mile engine. Both your reports look reasonable to me. Might even try a 40 grade and see how it does.
