6346 kilometers (3943 miles) on oil change, 42092 kilometers (26154 miles) on engine
I noticed that there is no fuel dilution listed on the report. I am thinking that something was maybe missed in the data entry, as all others have had reportable limits. I ran this oil a little longer than the others, & everything looks good, except for the Boron levels.
Not sure if it would be a problem to run a little longer OCI, considering the depleted Boron levels, or if it is an issue at all. I would like to run about 7500 - 8000 kilometers on the synthetic PP 5W-30 oil.
I have recently got back from a trip, out into British Columbia mountains, & have had the best fuel economy on the last 2 fuel ups since owning the truck. Maybe the rings have finally seated. I have been logging fuel consumption on the Fuelly app, and last 2 tanks were 11.9, & 11.6 Liters / 100 km. (20.4, & 19.8 US MPG) Previous best was 12.3, (19.1 MPG) & I usually had to drive below 100 km / hr to achieve this. The only other thing I done differently was to remove the engine cowling (cover) over the intake. Not sure if just a coincidence, or if it is helping to keep the fuel / air intake cooler.
Code
Aluminum 2
Chromium 1
Copper 6
Iron 11
Tin 0
Lead 0
Silicon 6
Molybdenum 77
Nickel 0
Silver 0
Potassium 1
Sodium 2
Boron 78 (Lower Critical)
Barium 0
Calcium 927
Magnesium 613
Manganese 1
Phosphorous 556
Zinc 630
Visc 40C 48.6
Visc 100C 9.0
Visc Index 168
Fuel % (No levels reported, possible data entry mistake?)
Code
Aluminum 2
Chromium 1
Copper 6
Iron 11
Tin 0
Lead 0
Silicon 6
Molybdenum 77
Nickel 0
Silver 0
Potassium 1
Sodium 2
Barium 0
Calcium 927
Magnesium 613
Manganese 1
Phosphorous 556
Zinc 630
Visc 40C 48.6
Visc 100C 9.0
Visc Index 168
