Pennzoil Platinum 0w20
North Carolina
Thinking of running Pennzoil Platinum in my new 2026 Equinox but don't like the lower flash point compared to Quaker State Synthetic which is much higher. Is this a valid concern?
If you’re looking for a 0w20 D1G3 oil, I would look into Castrol EDGE Extended Performance. That’s what I’m running in my ‘23 Blazer. It’s the only D1G3 with a stout MB approval.
This or Mobil 1 Truck and SUV would be my picks for D1G3. I was going to recommend PUP but you’re nervous about warranty.
Has GM made Dexos R backwards compatible to D1G3?
I hadn’t heard anything about that, but looking into it, it looks like it. However, only a replacement for the appropriate viscosity. So, kind of but not really I suppose. Most D1G3 oils are 0w20 or 5w30 with I think maybe one 5w20 from Motul if I remember right.
  • Like
Reactions: GW.
The QS is probably tested to the D92 standard, whereas the PP is tested to D93. D92 reads higher by ~20°C. Now, the QS datasheet says that it's tested to D93, but that's probably an error. A 0W-20 oil won't have a D93 flash point of 239°C.
Regardless, flash point has no direct impact on an oil's performance. In fact, higher quality base oils often have a lower flash point than lesser quality base oils. I wouldn't use it as an indicator of quality unless you're trying to use it to determine the type of base oil is being used, which isn't very straightforward.
I haven’t read anything here that’s positive about PP. Multiple negative reports frankly. I’d avoid. Take @Glenda W. ’s advice.
I think it's a very very average synthetic. Pennzoil has a very mediocre line. There is a Shell Euro oil that's good. PUP is good but not readily available. Not sure how great the current version is though.
