Pennzoil HM vs Mobil Super HM
Maxlife has a very stout cleaning package as well as it uses both calcium and sodium, not just calcium.
Your real dilemma is whether you want thick or thin, both Mobil and Maxlife are resource conserving whereas the Pennzoil along with Castrol High Mileage remain "thick for grade" High Mileage oil hold outs.
I really like the Pennzoil High Mileage as it is thick for grade and uses a very stout traditional add pack (moly and boron with high calcium) but I have used Maxlife extensively also and never been disappointed other than it was noisy in my Jeep. The Sebring has been on Maxlife for years and thrives on it.
No experience with Mobil.
I'd like to see the comparisons between Pennzoil Platinum High Mileage and Valvoline Synpower with Maxlife technology. Both full synthetic High Mileage oils. Would either of those clean better than their synblend counterparts?
Originally Posted By: aquariuscsm
Pennzoil.
Me too. I'm less comfortable with the higher sodium oils. And on paper I like the higher Moly and Boron of Pennz.
I used Mobil in my old Camry with 300k mikes. Definitely reduced consumption by the end of the first 5k oci. Just put the pennzoil in my ltd. Would be hard to compare them because they're very different cars.
I've used both Mobil super and Pennzoil High Mileage. I've settled on the Mobil super HM. It's much less noisy than the Pennzoil High Mileage in the cold weather, it's a synblend and it's usually cheaper. I'd had no problem running either if one was out.
Pennzoil High Mileage is a conventional oil, not a synthetic blend.
They're all good. But your motor will like one above the others. Do 4K OCI's and listen to what the motor sounds like on cold start and hot valve train noise on each. It will become clear in a few changes which your motor likes the best
Originally Posted By: _MAXIMUS_
He said pennzoil platinum high mileage. Which is a synthetic
Read again. He asked how MaxLife Full Synthetic or Platinum High Mileage Full Synthetic compare to their "SynBlend counterparts"
The only SynBlend counterpart is MaxLife SynBlend. The Pennzoil High Mileage is conventional.
Good catch! I should have said synblend and conventional counterparts. Are the additive packs of the synthetic High Mileage oils the same as the synblend and conventional oils?
I hear and read about rumors that Pennzoil conventional has "some" synthetic base oil in it. If so, wouldn't you think the same for Pennzoil High Mileage?
I figure it's all just rumor and urban legend. But then again,what does synthetic even mean anymore these days besides clever marketing gimmick.
