Penn Syn Blend or SuperTech Full Syn?
Originally Posted By: otis24
I tried removing my PCV valve about a year ago. Chewed off the stem. Darn valve wouldn't come out. I was content to get the hose back over the valve and it worked fine. If it were easy to get to (it's not), I would remove the valve cover and push it out from the back side. At this point, I am content to leave well enough alone!
Was the engine cold? I've had better results pulling the valve from warm (not hot) engines.
As I recall, the engine was warm when I attempted to remove the pcv. I still have the new pcv. When warm weather gets here, I will make another attempt.
I hear ya, its a major PITA to get to without removing the wiper tray. I also thought about removing the valve cover to attack it from the bottom...I read that there is a baffle under the PCV hole so you can not push it out! If I can get my wiper arms off this spring I will go the wiper-tray-removal route.
Good luck to ya.
