Originally Posted By: expat
We are almost ready to run now, but have a small problem.
We understand that the Pelton wheel should never run without a 'load' or resistance. I'm not too sure why? But suspect that the turbine may over rev and Burst if there is no load.
So the question is, What would be a suitable load?
The power going to out battery pack and control panel is routed through a 60amp breaker, the voltage from the Pelton wheel generator is 24v so I guess we are dealing with a potential of 1440 Watts? But I doubt the wheel will ever , realistically produce this. Many suppliers sell heating elements for these Power dumps, some suggest multiple elements that are 'Specially wired for 24volts ??? They are expensive!
What would be wrong with using a 'normal' 110volt household heater for the Dump? (At least until we can test and get to see how many Watts we will have to deal with)
What would we require in a 110v rated heater to deal with 1500 watts at 24V?
What would happen if the Dump receptacle (Heater) was too great a capacity? Someone said it would stall the turbine!! My Gut says Garbage to this! What do you think?
Thanks in advance.
A pelton wheel at no load will turn twice as fast as it will at full design load. Maybe not a problem in a small well built wheel, but I'm not so sure about your generator being good for double design RPM.
To save me some typing about wheel load vs speed, see the end of this article
http://eetd.lbl.gov/inventors/hydro/hydro-learn-adv-eu.html
A 1500 Watt heater would absorb a lot less power at 24 volts. You won't hurt the heater but you might not get as much load as you want. If heater resistance were a constant as voltage varies the heater would only load 24 volts to about 60 Watts. It will actually do a bit better, maybe 80 Watts.
