I never used premixed coolant in my truck, until I recently did a cylinder head overhaul. I always used a 40% coolant to 60% distilled water ratio, and mixed it myself (using Dia Queen or Motorcraft Premium Green Coolant).
When I was purchasing parts for my overhaul, I had a significant amount off Mitsubishi Genuine Premixed Coolant (70/30 ratio), so I went ahead and bought 12 litres (10.5L capacity overall). Thought it was more convenient as well just to pour in, instead of mix.
After I refilled the system, I noticed white traces of coolant on my distributor cap and water pump surround, going all the way to my wiper motor. I even noticed coolant coming out of my throttle body coolant hose. It wasn't worn out or anything, there was a wee bit of foamed coolant at the tip of the hose, past the clamp. I had to top up with distilled water (about 500 ml) every day. I cleaned up all the residue whilst I was topping off as well.
Now the more I topped up, the less residue was being left on the said areas and the less frequent the topping up. This went on until I no longer had to top off the coolant everyday. It was more like once every 10 days or so.
Three days ago, the expansion tank was a bit low on coolant, so this time I refilled using what was left from the premixed coolant as opposed to distilled water. As soon as I did so, the amount of residue on the said areas started building up and I had to top off frequently again (daily).
I'm quite confused, because this has never happened before. The higher the ratio of distilled water to coolant, the less I had to top off and the lesser residue. Afterwards, I had enough and flushed out all the coolant with distilled water and mixed in Motorcraft Premium Green. Problem disappeared completely - no topping up required since.
Maybe this particular coolant wasn't that well suited to my application?
