You mean everyone doesn't do that??quote:
Originally posted by Patman:
I can just picture some of you guys going into your fridge and taking out your Brita so you can get clean filtered water for your cars!
The SCA (supplemental coolant additive) chemical in a diesel cooling system coats the outer surface of wet liners and prevents cavitation erosion.quote:
Originally posted by manualman:
Ken2, you appear to have a hole too. Cavitation is more a mechanical, than chemical phenomenon. Unless those additives you mention significantly increased the viscosity of the fluid, they will NOT prevent cavitation. I may not know my chemistry well, but I know my hydraulics. Cavitation can be a very destructive force in a pumped system.
Exactly, anyone remember colligative properties??quote:
Distilled water boils just fine. The nominal boiling point of 212 degrees is based on distilled water. Water boils slightly LOWER with nothing dissolved in it. dissolving anything in it lowers the freezing point and raises the boiling point unless the solute has a lower boiling point than water. .
