On my T4R I usually take out the PCV and inspect. I also remove the PCV Grommet from the valve cover and inspect for any cracks or leaks etc. I'll use some hot water and soap to clean them up and give the Grommet a good spray of silicone after it drys.
Sometimes I find that these need replacement, due to cracking, rather than the PCV valve and they are cheap enough to replace. IMO...the Grommet is just as important as the valve in the PCV system.
Most of the PCV valves that I have change out on my vehicle are soaked in either carb cleaner or brake cleaner in a small "Baby Food" size jar for a day or so. Sprayed clean and then I use a can of compressed air to dry them on the inside or blow any residual moisture out.
In most cases I've been able to recycle the PCV valves and Grommets with no problems. But as with everything YMMV.....
