BlueOvalFitter
Okay, y'all are going to make me type it.
When I bought my F150 brand new with 6 miles on it, after about 1400 miles the engine started detonating so bad it sounded like a pack of wood peckers on street lights!
I took it into Gator Ford in Seffner, FL. and the tech assigned the job found BOOKOO amounts of oil in my intakes (yes, plural; upper and lower), IAC, TB, valves, and piston tops (after using a Bore Scope down the lower plenum-spark plug holes). They had to pull the WHOLE top end of my engine, including the heads. There was so much oil and carbonized oil on the piston tops, they had to call in an engineer from FoMoCo. In the meantime, I was provided a rental LARIAT F150, FREE of charge of course.
Anyway, the engineer found out why there was BOOKOO amounts of oil being sucked into my my engine, in turn causing the harmony of detonating wood peckers. My engine became famous! That engineer had to redesign something in the pcv system to not allow oil to be sucked into the 4.2 V6 ever again.
After a thorough cleaning with BG products, they reassembled my engine and it was as good, or better, than new. I am thinking that the engineer could have gone the route of installing some sort of catch can, then if so, the owner would have to monitor it. Ford couldn't have that. So, they redesigned the pcv system.
WHEW! Too much typing!
