when I had one, I did the same, and went and left the system on the truck and just gave it awayquote:
Originally posted by mjo:
I am using a catch can and a bypass filter. The oil getting caught in the catch can looks clean so I just pour it right back in. I'm loosing very little oil this way.quote:
Originally posted by mechtech:
I don't see any means whereby oil consumption would be reduced.
The reciculated oil/blowby is now trapped [to be drained] - that's all.
I drive about 30% city, 70% highway. I probably collect a half a cup every gas fillup. It has a medium brown tint to it so I just pour it back in. I use 100% synthetic - both Redline and Mobil 1 (my favorite). The air compressor dryer (that looks BTW exactly like surfstar's) leaked on the bottom. So, using needle-nose plyers, I removed the bleed valve and filled the hole with epoxy. It hasn't leaked since. It's good to remove the styrofoam insert that is between the inlet and the outlet. That is, you don't need to filter the air - just have an expansion tank to condense the heavy oil vapor.quote:
Originally posted by VelociRacer:
How much oil do you collect in, say, 3000 miles? What's your city/hwy split?quote:
From my experience, I really think that the canister itself is sufficient to catch most of the oil without using the filter. The canister acts like an expansion chamber allowing the velocity of the vapor to slow way down. When this happens your oil spray, which is heavier than air, will find its way to the bottom. I believe that any restriction between the pcv valve and the intake will inhibit the job of the crankcase ventilation system. When that foam "filter" gets saturated with oil it will render the catch can useless.quote:
Originally posted by surfstar:
mjo, i'll remove the filter stone and watch for changes. i did remove a little deflector that was inside the filter. i would assume that the filter with all those pores would help to condense the oil, but i don't want it to restrict flow.
or maybe i'll drill a larger hole in the bottom of the filter to give it high flow.
Actually, the filter element is not foam but a stiff and almost solid porous plastic substance.quote:
I have a Saturn 4 banger car so the operation of the two PCV valves could be different. But, perhaps your PCV valve was stuck open and needs cleaning out or maybe the canister wasn't tightened completely?quote:
When I installed this, I removed the filter and the PCV vacuum was so fast through it that it was literall vausing a vacuum leak and the engine rpms were 50rpms above normal and the air velocity was so high through the separator that some of the trapped oil was getting suckked back up into the intake.
I found it slowed the slow with it installed and the engine rpms went down to normal.
You have a valid point there, but everything is brand new. It was just allowing too much PCV gas through it.quote:
