- Joined
- Sep 28, 2002
- Messages
- 39,793
I've recently had a number of anomalies occur in my 02 Wrangler.
One night in the single digit temps I started the jeep and I found my odometer reading being displayed. I always leave it on the trip odometer. Flipping to it, it was found to be @ 0.0. The radio, while retaining its presets, was on AM and at 500khtz. End of story ..shrugged and moved on.
I had my wife drive the jeep to put some mileage on the 0w-10 with her 50mpd commute. On the second or third day she reported a CEL and quickly confirmed that all the gauge indications were normal (oil and whatnot were good).
Upon scanning it, it was found to be "Cold too long" in the FSM. I told her not to idle it before leaving work in teasing her. She asserted that she did not ..I said Liar-liar-liar
since I could drive it less than a mile and reach almost normal operating temp. Her cycle before getting on the highway would be longer ..therefore it should not have occurred.
I then encountered the same event a couple of weeks later. Teh gauge didn't appear to be low, but at one point the CEL came on and you could hear the engine change. I'm speculating that it came out of fuel enrichment. Now my spider sense is tingling. I apologized to my wife (this is not always wise- opportunity presented).
Move to two nights ago. I go out to start the jeep and NOTHING. Turning the key yields ZIP. I then open the door and as the dome light gets triggered - Sha-ZAEIM (said like Gommer Pyle) everything comes back.
I don't think that I have a BCM (body control module) ..maybe I do ..but there are a few body functions that appear to be integrated into the PCM. For example, if I leave my lights on, when I open the door and the dome light turns on, the high beam indicator will blink with the chime. My dome light also turns on when I turn off the key.
Even if this was a faulty BCM (if indeed I have one) I can't see how this would relate to the too cold too long issue and I can't manage to see how they're not related.
