PB Blaster with a straw and flow volume control
Near the beach in Delaware
I purchased this awhile ago and have used it several times as I can get the lubricant exactly where I want it with the attached straw.
It has a lock/unlock slider so you cannot accidentally spray the product. Or so I thought
The slider is actually not a on/off but a way to prevent you from pressing the button all the way down. So one can set it on 1/4 blast or 1/2 blast, etc up to full blast.
Bottom line is if you just need a tiny squirt on something this will allow it.
I recommend getting a can and trying it.
So I have had the can for over a year and just noticed this feature today.
Thanks! I just used this can today and got too much squirt because it's on full blast, now I know. Just looked at the can and sure enough it explains the volume control feature. Duh. Not a fan of how it dribbles out a few drops after you put the straw down.
Years ago I emailed the company saying the basic can says you can use at any angle including upside down. Yet when I tried it ran out of aerosol before it ran out of lubricant. They emailed me back saying marketing must have put that in there. But it's not correct. The guy shipped a case of PB Blaster to say thanks for bringing it to his attention. I am 72 and still have 10 of 12 left. Unsure if I will use them up in my lifetime.
used the multi-max with the smart straw a couple days ago, believe I wasted a lot less oil and the dam door is quiet as a church mouse while operating, hats off to B'laster
