grooved pavement
how much does traction go down?
a bit, none at all?
What about wet vs dry?
Having done COF studies ( traction is a measurement type of COF), I seriously doubt you will ever see a legitimate one ( peer reviewed or certified by an individual or organization) addressing your key points because of the cost and potential liability of the published results.
Granted most of mine are on conveyors and drag links but fundamentally there's little difference between them and a tire/road traction event.
For example, for me to address that ( talking an official report with my stamp that makes a proclamation based on legitimate scientific techniques)
The results would only be valid for the specific car set ( establishes contact geometry, weight, angular acceleration etc.), the exact tire ( compound, size, inflation, tread pattern/depth, age)and stuff like incline, speed, angle etc.
Any one or all of those will significantly change the COF of a tire/road scenario.
Then stuff like grooving ( changes surface contact area and contact profile), type of asphalt ( surface asperities), wetness and all that.
That's a LOT of variables to capture and calculate to determine a ratio of traction for numerous considerations.
Even then the results would only be valid under test conditions with the test vehicle set up so results would vary against other vehicles.
That would be a lot of money and effort to get a study that had such a limited value and application.
