Originally Posted By: IndyIan
Originally Posted By: CapriRacer
I have spent a lot of time talking to RV'ers - and their opinion is that ST tires are to be avoided. They seem to fail way too often.
Many are moving to LT tires - but the problem here is sizing. There is very little commonality - especially in 15".
Also, many are using P metric tires, but they have to be derated by a factor of 1.1 if used on a trailer.
So to answer the OP's question, Yes, I think using Passenger car tires is OK in your application. Just inspect them on a regular basis.
So would you say that the OP tires would be good for 3400lbs? I found they start to look abit overloaded and heating moderately with 2400lbs.
Well, you forced me to do the math.
A P205/75R15 Standard Load has a rated load carrying capacity of 1598# at 35 psi. That means its rated load carrying capacity for trailer use is 1453#. I like to use a 15% reserve in tire loading, so the usable maximum load is 1235#. And assuming the load is not more than 10% side to side variation, that makes the load limit 1111# per tire.
Assuming there are 2 tires, and that the tongue weight is 10%, then I think the GVW of the trailer should be less than 2470#. Since the OP said he doesn't haul more than 1200#, that means his empty trailer can weigh up to 1516# - and that's a reasonable value for a small utility trailer.
And to answer your question: No, I don't start off with the same values the OP did and I certainly don't wind up with the end result you got.
