Anybody still using this stuff? Park's been making it forever so it must get use but I haven't really ever loved it in bicycles. I have my other go-to choices but wondering if I'm missing out on this.
I have a tub of it, which I use on bike stuff. No idea if it’s better or worse than anything else.
You mention other go-to choices - care to share what and for what uses?
If you have others, curious why you’re asking about this stuff at all?
Yeah I’m just more curious than anything particularly because I’m tuning up my wire’s road bike right now for a triathlon she’s doing.Well you name it and people like it. Myself, I like the Phil Wood for "nice" stuff and Superlube grease for anything and everything.
Exactly. Fill it with any quality grease of appropriate viscosity and you'll have something at least as good as any bicycle-specific grease, at a fraction of the cost. Another that makes a good all-around bike grease is Schaeffer's 221, #1 or #2 depending on the viscosity you need. Plenty of other good choices too.... Mobil Polytex EM is a polyurea grease and specifically intended for ball bearings. A standard grease gun tube size is alot cheaper than Park
Use silicone grease to lube cables. Slicker than cat poo. I use Permatex dielectric or similar (not cat poo)Yeah I’m just more curious than anything particularly because I’m tuning up my wire’s road bike right now for a triathlon she’s doing.
So Phil wood is the stuff for bearings and whatnot?
I have and love super lube, both silicone and synthetic. But I don’t know where I’d use it in a bike.
I use the park also like antiseize fwiw.
You are able to run a chain to those miles wo lubing? Gota tell me what chain brand can do that!Every 500 Miles my cassette comes off and gets cleaned along with the entire bike and chain.
That's a very minimum maintenance. My electronic shifting doesn't go out of adjustment unless it's fiddled with.
So for the most part a little Polly Lube on the pedals and crank arms and Sram butter for internal components. But nothing is going to sit on this bike very long due to my 500 mile maintenance regiment.
I personally think you could probably use any kind of Grease or Lube for modern bikes since they are all sealed bearings now. And if you clean them regularly it doesn't really matter. There's no Holy Grail grease or Lube or oil. Like somebody else said, everyone has their favorite.
A lot of people like waxing their mountain bike chains. I find waxing is just a big bunch of crud that builds up on your cassette and chain.
Very hard to clean off and reapply. I'll just run a chain for a 4 or 5,000 miles and just replace it, it's not that expensive.
Just my two cents.
Rockshox also labels/brands this stuff. It's designed to minimize "sticktion" which is ideal for shocks, seals and suspension bushings. But bearings have different requirements, such as high film strength and barrier protection additives. So it's not ideal for that application.Unknown to me, was told it [SRAM Butter] was good to use on bicycles. I also use.
This appears to be a really good quality. And was told to use this on shocks and seals. So whenever I do maintenance on my Hub I use the SRAM butter.
Same here.Well you name it and people like it. Myself, I like the Phil Wood for "nice" stuff and Superlube grease for anything and everything.
That photo brings back old memories for sure - looks like they haven't changed the tube in 40 years.
I have a large tub of that stuff, and if there is anything special about it, I can't tell. In fact, I don't even like using it.Shimano "DuraAce " green grease is a highly praised premium bike lube but very expensive. Its the iridescent yellow green stuff. IMO , it's the best bike lube. Based on my research, I believe Its a calcium sulfonate grease.
... I'll just run a chain for a 4 or 5,000 miles and just replace it, it's not that expensive.
